![]() Drives: 2010 Camaro SS2 2012 C6 vette M6 Join Date: Jan 2022
Oil Weight
As experts on Super charged cars I would like your opinions on what weight t you use for normal oil changes. Some people think heavier like 15-40 or 20-50 some people say 5-30. this is a un touched LS3 with Heartbeat PD SC. Do you prefer Mobil One Shell Rotella? thoughts?
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Fresh oil is good insurance. IMO, with your setup (you didn't mention driving style, racing or other mods), 5w-30 Mobil 1 is ideal. Walmart, 5qt, inexpensive and the Mobil 1 M1-113A oil filter.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
This.
#6 |
I use Driven LS30 (5w30) in mine.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
#7 |
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
xxW/30 is important.
#8 |
#9 |
![]() Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
Depending on the engine builder. If OEM Motor clearances are made for 5W-30 would be the recommended weight. Now that if for your street/strip car. If it is a race car, possible 5W-40 May work well while racing. For Example, in my motor that we build. we will be using SAE40 VR1. In a high-performance motor, you really don't want detergents in the oil, nor for the oil to really change viscosity. You want consistent protection. Which a change in viscosity CAN lead to foaming within crank and not really getting the true protection the oil as a lubricant offers.
#10 |
#11 |
