Old 01-20-2023, 09:48 AM   #1
Shawn Sapp
HLF NKD
Drives: 2012 RS convertible
LFX engine Swap
I am in the process of swapping out my LFX motor and I am wondering how do I know that the used motor I am replacing it with is in fact an LFX from a Camaro and not one of the many other versions from other models? I tried looking online for a ESN look up to to no avail. Any help would be greatly appreciated.
Thanks,
Shawn Sapp is offline   Reply With Quote
Old 01-20-2023, 10:48 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
Not sure if this helps: https://www.camaro5.com/forums/showthread.php?p=346288
Any pics of the engine? Different vehicles used different intake manifolds so that might be an easy way help narrow down what it came from.
KillboyPowerhead is offline   Reply With Quote
