![]() Drives: 2018 camaro zl1 Join Date: Jan 2023
so pretty much, i was getting a code for knock sensor and everytime i push the car to the limit the engine light comes on and i loose a lot of boost of the supercharger the code for knock sensor comes up but after the car been stopped for a few hours it goes away so i decided to replaced it but still everytime i drive using the full power of the car after few minutes it comes back again. i dont know what to do its so annoying when the power is reduced. what should i do?
p.s a performance mechanic changed it for me. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
I would start by posting this in the Camaro6 forum, but knock sensor sensitivity could be set wrong or too much timing is really causing detonation.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
could be low octane gas, even if you put it in yourself from xyz gas station, it could have low octane in their tanks.
| Tags |
| annoying, boost, help me please, knock sensor, zl1 |
