Old 02-02-2023, 11:43 AM   #1
Jaron’s SS
Drives: 2010 Camaro Ss/Rs
Service Stabilitrak after new tires…
Yes I know now, my tires are too far apart. I put on nitto nt555 g2’s, fronts(255/35/20) and rears(295/40/20). Threw the code and turned on all the lights just a few hundred feet from the tire place. Any easy fixes? Recommend front size so that it doesn’t throw the code? I’m not very experienced or knowledgeable with tire sizes so i really need some assistance. Thanks in advance.
Jaron’s SS is offline   Reply With Quote
Old 02-02-2023, 12:04 PM   #2
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
The difference in overall height between the front and rear tire is my guess. Thats an 8.5% difference and I believe the max difference it can be is like 4-5%. You essentially have a 27" tire on the front and over a 29" rear tire. Either go taller on the front or shorter on the rear. A 275/40 on the front would probably fix your issues.
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 02-02-2023, 01:51 PM   #3
Jaron’s SS
Okay, I have copied this comparison. Will getting the 275/40 on the front get rid of my issue?
Whl1(275/40) Whl2(295/40)
Diameter 28.7” 29.3” +2.1%
Width 10.8” 11.6” +7.4%
Sidewall 4.3” 4.6” +7%
Circumference 90” 92” +2.1%
Revs/Mile 704 689 -15
Old 02-02-2023, 01:53 PM   #4
Arogg
Arogg's Avatar
I think you should be good. 2% should be within the threshold. If I remember correctly, those are the exact tire sizes I have on my car with the Nitto NT555 as well.
Old 02-02-2023, 02:05 PM   #5
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
For Nitto G2s: 255/35/20 = 27.01" diameter. 295/40/20 = 29.29" diameter. Don't know if your lowered, suspension has sagged, different rims or ???? So I'd replace front and rear with something close to the factory diameter, ~28.7" front and rear. You could roll the dice and install 255/45/20, 29.06" G2s on the front. They shouldn't rub. Did the tire shop recommend your current sizes? Larger tire will mean your going faster than your displayed speed.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 02-02-2023, 02:54 PM   #6
Arogg
Arogg's Avatar
Play with the tire size calculator. Like I said, you want them close in size but you dont want taller sidewalls on the front than the rear, that would look terrible. Im pretty sure im running 275/40/20 and 295/40/20 on my lowered SS
Old 02-07-2023, 03:45 PM   #7
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I would make sure the code is even relevant to the tires,it's possible it's something else.
If you want to keep the tires, someone with HPTuners can adjust your tune to accept the tires you want and your ABS and speedo will be happy again
FasNuf is offline   Reply With Quote
Old 02-07-2023, 03:53 PM   #8
Arogg
Arogg's Avatar
Its definitely the tires. Look at the sizes he posted. Way too far apart in size front to back
Old 02-07-2023, 09:30 PM   #9
Royal Tiger
Drives: 2013 2SS/RS Convertible
Use this:
https://tiresize.com/calculator/
It’s how I found what size to use with my drag radials.
Royal Tiger is offline   Reply With Quote
