![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Driveshaft Loop Option
Someone was asking about driveshaft loop options and after I looked at what BMR offers for the Gen6 I picked up a Summit drive shaft loop kit for $25. This is not meant to be a critique of my welding or a step by step how to, but just to show you what can be done fairly quickly with a welder, cutoff wheel and hand drill to keep from beating the car to death should the driveshaft let go.
This pic shows what I was originally thinking, but the bottom part of the loop is about 2 inches too long for the exhaust. The kit was not designed for such a narrow tunnel so you have to cut a lot of material off the mounting tab and use what amounts to a small piece of angle iron. This pic is how I modified it to not hit the exhaust. This actually left enough material from the kit to make another, which I will likely do if I decide to put one in the vert. I bolted it where the stock carrier bearing goes. Which there were two more bolt holes, but not really concerned. I forgot how much closer the driveshaft runs to the passenger side, so be sure you take that into account when cutting the tabs. I just centered it and it's much closer to the passenger side.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. Last edited by CamaroCracka; 02-09-2023 at 06:45 AM. |
Thats a great idea CamaroCracka!
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
Nice work… It’s fun to be able to modify and adapt pieces to work to a custom standard…
I purchased a kit for a 5th Gen at one time and then had to modify it when we went big…. This was my first ever attempt to Tig weld, and thank goodness it was steel rather than aluminum… I freely admit after Tig welding steel, I thought I was good to move to aluminum… not so much…. lol… Essentially what I did was cut the original base, add two strips of like flat material to lengthen it, and then cut and formed the side gussets to strengthen it all…
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
Nice work. That looks good enough to be somewhere people can see it.
One question: do you still run the stock two piece driveshaft at your power level?
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#5 | |
Boosted Moderator
And that only looks good enough to be seen after the Krinkle black paint job…
#6 |
Thanks for the info. I'm thinking I need to go to a more local shop and get chromoly unit.
#7 |
Boosted Moderator
Curious, why chromoly???
#8 |
Seems like that is the strongest and a lot less costly than carbon fiber. I also believe they will hold up better over time than carbon fiber. I've just never had an issue with steel driveshafts.
#9 | |
Boosted Moderator
The 4” shaft Thrash built me was aluminum… I just went and did a bunch of reading… Interesting comparisons…
