Old 02-13-2023, 10:04 AM   #1
2SSHADOWLSX
NightFuryCamaro
2SSHADOWLSX's Avatar
Drives: 2012 Camaro 2SS
Question ELSD Rear End
Hey, wondering if anyone here knows of an aftermarket ELSD
equipped Rear End that is easily swapped in to the 2010-15 Camaro SS. Apparently it's a huge upgrade and allows traction to be had almost anywhere at anytime. Would love to get my hands on one.
2SSHADOWLSX is offline   Reply With Quote
Old 02-13-2023, 01:53 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I don't think an ELSD would be much of an upgrade. I've had one in the front diff on my truck for about 15 years (e-locker really) and they work well for that application, but for a car they won't do anything for you unless you are spinning only one of the tires. Now, if you have computer controlled all wheel drive, it might help, but probably is not worth the cost. You would probably be better off spending your money elsewhere.
Old 02-13-2023, 03:29 PM   #3
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
The Eaton Truetrac is a good option.
https://www.phastekperformance.com/E...ac-912a686.htm
Sales@Phastek is offline   Reply With Quote
Old 02-13-2023, 10:32 PM   #4
2SSHADOWLSX
NightFuryCamaro
By ELSD I meant Electronic Limited Slip Differential. The new Camaro ZL1 in the 6th Generation has it. I'd like to get in on the launch gains they give you.
Old 02-13-2023, 10:47 PM   #5
2SSHADOWLSX
NightFuryCamaro
Phastek?
Also, what do you have to get with that piece? Doesn't look like it comes with a housing or axles. What else is involved to make it work?
Old 02-14-2023, 06:58 AM   #6
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I don't notice much. I can still spin the wheels at highway speeds in my Z06. I would upgrade my tires first if I were you.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 02-14-2023, 09:22 AM   #7
2SSHADOWLSX
NightFuryCamaro
My tires are R888R 315s. I'm aware it isn't a surefire solution to spinning, but I'm also aware it's better to have it than to not.
Old 02-14-2023, 09:27 AM   #8
gtstorey
I don't know how ELSD would be any better than mechanical without full integration into the vehicle control modules with full programming to take advantage.
Old 02-14-2023, 09:44 AM   #9
TheFlyingBananaSS
This⬆️
Old 02-14-2023, 09:46 AM   #10
TheFlyingBananaSS
Gave you the follow on IG.
Old 02-14-2023, 02:40 PM   #11
CamaroCracka
This was my point.
FYI, electronically actuated carriers have been around for a long time. There are none for the GenV from the factory so any ELSD would just be a carrier you put in your diff. I would rather have a Torsen than ELSD. Mag ride was great feature on the GenV ZL1 and now you can't find replacement shocks. You will find yourself in the same position with that ELSD on the Gen6. Mary Barra thinks we all want to drive electric vehicles and they are discontinuing parts at a rapid clip.
aftermarket, elsd, rear end
