New Intake
Has anyone studied this intake or got an inside scoop??
https://shop.performancedesign.com/x...ifold-p29.aspx __________________
Orange Krush II
![]() Drives: 2010 Camaro 1SS Join Date: Nov 2015
That's pretty interesting at the minimum. The length of the runners does make a huge difference but I wonder what having all the fuel rail system in there will do with the air.
I'm curious what kind of power gains they'll get. Article from motortrend https://www.motortrend.com/reviews/p...ld-first-look/
I saw the article on Motortrend as well thats why I posted. Do you think they might be a little late to the game?
Orange Krush II
Tri-County Camaro SWFL
Yes they are. Theres so many proven intakes on the LS3 platform. The FAST is proven, rod mods are proven. High ram....proven. Too little too late. I skimmed through the motor trend article earlier this morning.
![]() ![]() ![]() ![]() ![]() Drives: Never just fly under the radar Join Date: Jul 2015
Like the look over stock I think. As for late to the party yeah a bit. But with so many LS swaps still probably room in the market, especially with the smaller sizing and ability to be put on with the TB facing back. Can see potential in those swapping into other vehicles at the very least.
Old Skool |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
The whole idea with the fuel rails in the intake I think is pretty stupid. My fuel rail on my FAST comes of with 4 screws. I had an injector o ring fail on me, alls I needed to replace it was an allen wrench.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
#7 |
![]() Drives: 2013 1SS Join Date: Jul 2014
yeah interesting to stick the fuel rails inside, but my first thought was honestly what happens if those fuel rails happen to leak, now you are spray fuel uncontrolled inside the manifold, that sounds like a bad day, i'd honestly rather the fuel spray into the engine bay rather that into the manifold, it does look clean though I'll give them that
2013 1SS M6 | Bo-white ported TB | CAI Intake | JRE Race Scoop | Manzo headers/catback | BMR motor mounts | Revshift poly insert transmount | EE Catch can | GM Strut Tower Brace | SJM Line lock
