Old 02-19-2023, 03:00 PM   #1
rich2342
rich2342's Avatar
Drives: 2010 CGM Camaro SS
LS3 Heads and other good stuff!
I have a good condition set of OEM LS3 heads with upgraded Cam Motion Spring set. 700.00
1LE Front /Rear Shocks and Struts w/Hotchki 1 inch springs.
500.
Cam motion LS3 stg 3 Cam Used for about 10k miles. 250.00
LS7 water pump. MAKE OFFER.
Brembo Front Caliper with new pads. Make reasonable offer.
Not pictured Left side 4 coil packs with bracket. Make offer.
rich2342 is offline   Reply With Quote
Old 02-19-2023, 05:06 PM   #2
sdynak
Drives: 2014 ZL1
What core & lift options on the CM-3? Any dyno results?
2014 ZL1 Black All OEM, Manual
SOLD: 2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 02-19-2023, 05:09 PM   #3
rich2342
rich2342's Avatar
222/230 .595/.595 lift 117 lsa if I recall. Put down 447whp 440 wtq. Great sporty cam with instant response and pull low to mid upper rpms.
I had a few nice kills with it in my 6spd.
Old 02-19-2023, 05:15 PM   #4
sdynak
Drives: 2014 ZL1
Nice.. mine is a bit overkill for my use and looking for something a little more mild mannered with low end response. Any chance you know the core type 5150 or 8620? I assume it is a 3 bolt?
Old 02-19-2023, 05:33 PM   #5
rich2342
rich2342's Avatar
This might be the one for you. It is not rowdy. Instant torque off the line. Very fun in that regard.
I am pretty sure it is the hardened core. I have never gotten softer materials due to my fear of scoring etc.
Old 02-19-2023, 05:38 PM   #6
sdynak
Drives: 2014 ZL1
Thanks.. if you could verify the lift and core that would be great.
Old 02-19-2023, 05:47 PM   #7
rich2342
rich2342's Avatar
Ok, apologies. It is the 5150 core. My second cam I got 8620.
Specs are attached high lift version.
Old 02-19-2023, 05:54 PM   #8
sdynak
Drives: 2014 ZL1
Thanks.. I'm tossing a few things around so will let you know if I decide.
Old 02-21-2023, 10:52 AM   #9
rich2342
rich2342's Avatar
Bump
Old 03-09-2023, 09:39 PM   #10
rich2342
rich2342's Avatar
Bump
Old 03-16-2023, 01:42 PM   #11
rich2342
rich2342's Avatar
Cam motion camshaft has been sold.
The rest is still available.
Old 04-10-2023, 08:46 AM   #12
Scotty D
Drives: 2014 1le 1SS CRMT
Heads still available
Scotty D is offline   Reply With Quote
Old 04-10-2023, 09:10 AM   #13
rich2342
rich2342's Avatar
Heads are sold! Other parts still avail.
Thanks
Old 04-12-2023, 02:19 AM   #14
SShadow305
Drives: 2011 Camaro SS A6
PM sent
SShadow305 is offline   Reply With Quote
cam motion, camshaft, hotchki, ls3 heads, suspension
