![]() ![]() Drives: 700 rwhp 2010 SS Join Date: Sep 2010
Cam "chop" gone after e85 upgrade
So I bought this car in December and the first video is how the car sounded on 93 and meth Injection. You can hear it was really choppy, the second video is how the car sounds after the second owner installed a fore tripple pump system, 1700cc injectors and e85 tune. Would the choppyness being gone be due to the tune? I noticed this car is super fat on the bottom end. Idles around 11.4 afr. I'm having it retuned in may by a shop I trust. It makes around 850-900rwhp I'm told on 18psi with twins. What do you guys think?
https://imgur.com/a/8kdUia0 https://imgur.com/a/5Gaz9qX
![]() Drives: 2013 ZL1 Join Date: Sep 2021
Yes the tune can affect the chop, If your running E85 you need to read Lamda not AFR.
#3 | |
I was just reading off the afr gauge in the car
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Does it actually have a larger cam? Or was the original a "ghost" cam in the tune?
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
The E85 modifier table (called Flex Fuel Spark) most likely added/removed idle timing and the result ended with a smoother idle, if that's the route the E85 upgraded was incorporated into the tune (the right way). If they just modified the main spark tables, there is a slight difference in how the difference fuels likes spark (how much). Easy to change in tune to get it where you want.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
#6 |
It does infact have a big cam in it, the motor is fully forged and built.
#7 | |
Good to know!
#8 |
If you are running E85 you don't want a 14.7-1 ratio. E85 is 9.8-1 your gauge should have a setting for lambda . If you go by AFR you have to know what mix of gas and alcohol you have-you would have to recalculate every time you fill up. Lambda will always give you an accurate reading no mater what the mix. An added bonus its much simpler to understand. The ideal target is 1 lower than 1 is rich higher than 1 is lean. I have a feeling the tune you have now is probably spot on.
https://ftyracing.com/tech/lambda-afr-table/ |
