Old 02-28-2023, 08:27 PM   #1
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Whipple return style fuel system help
Can anyone who has done a return style fuel system on a whipple send me some pics of how they have their rails and the regulator setup. I received a quote that was astronomical for a custom plumbing kit. Thanks for any help!
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 02-28-2023, 09:55 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
What are you needing to know? I built my fuel system with some advice from other guys here.
Old 02-28-2023, 10:23 PM   #3
BigMatt
BigMatt's Avatar
I pretty much just need a visual on how to route the feed, regulator and the return lines with the whipple rails. A picture or 2 would literally be worth a thousand words lol. I'm going to be running 8 an feed and return lines, plugging the 6an feed on the side of the whipple rail, as well as replacing all of the qd adapters with 6an male to 8an male adapters. I'm just not sure how all of the plumbing should run.
Old 03-01-2023, 08:03 AM   #4
larry_g
larry_g's Avatar
Here's a couple of photos including a sketch of the layout concept. I ran the supply line up through the cabin filter box and then mounted the flex fuel sensor on the outside and plumbed it from behind. The Y split at the back was a PITA but it worked and I ended up mounting the regulator on the end of the fuel rail.
Let me know if you need more details. I can get more pictures if you need while the blower is off the car.
Old 03-01-2023, 07:25 PM   #5
BigMatt
BigMatt's Avatar
That is exactly what I was looking for. Thank you for posting that!
Old 03-01-2023, 09:27 PM   #6
larry_g
larry_g's Avatar
Anytime. Feel free to message me if you need anything else.
