![]() Drives: 2014 Camaro SS Join Date: Aug 2019
2014 Camaro Ss horn relay?
I’ve got a stuck horn situation and have tried everything where exactly is the horn relay located on this beast? I cannot find any documentation other than the location of the horn fuse! I have tried everything else short of replacing horns to fix this.
![]() Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
it's relay kr3 under the hood.
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I haven't confirmed the accuracy with the service manual, but the video that is just the diagrams from the 1JEWLDSSRS indicates the horn relay is non-serviceable. This typically means a relay on the distribution board inside the fuse box. Not 100% un-replaceable but you will have to have some soldering skills to do it.
#6 |
![]() Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
F51 underhood fuse box 15 amp
#7 |
I have the schematics, it's kr3 under the hood.
#8 | |
#9 |
Horn relay is not serviceable, Part of the underhood fuse block
#10 |
#11 |
#12 |
#13 |
That’s what I was afraid of, everything I’ve read and seen says that the relay is built into block and the only way to fix the issue is to replace the wiring junction box..
https://www.gmpartsoutlet.net/oem-pa...YtMmwtdjgtZ2Fz |
#14 |
You should be able to pick up a salvage one for less. I think it's very rare to have any problems with the non-serviceable relays.
