Old 03-01-2023, 03:57 PM   #1
BlackBird1
Drives: Chevy camaro SS
Rear Differential Convert to a posi trac
Has anyone converter the factory limited slip differential to a limited posi trac with Eaton Detriot posi truetrac differential? If so do you have step by step installation. Thank you
BlackBird1 is offline   Reply With Quote
Old 03-01-2023, 04:00 PM   #2
bottletalk
Drives: 15 Camaro 2SS M6
I did....download the instructions and follow them, then set up just like a ring pinion install.
bottletalk is offline   Reply With Quote
Old 03-01-2023, 04:01 PM   #3
gtstorey
It's going to be the same as any other diff swap or gear swap. You will have to have the know how and tools to measure and set it up. I think it's common on these to also need a case spreader.
Old 03-02-2023, 07:21 AM   #4
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
A case spreader is highly recommended, I didn't have one when I did mine and wish I did lucky I was able to get mine set with only having to pull it back out once. I also recommend getting a beam type torque wrench to set pinion preload. I replaced all of the bearings and seals and don't forget indicator to check backlash.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 03-03-2023, 01:05 PM   #5
SS_CTS-V
Drives: 2015 SS, 2006 CTS-V (wrecked...)
I tried, and failed, but I was also adding 3.91 gears. Lost patience with taking the diff back out to get the spacing and depth correct. Ended up, just buying a built unit from JRE. Not the cheapest option, but I know it's well built and will last. As a bonus I upgraded from 3.91 to 4.11 gears. Something to consider if you are not experienced with setting up gears. I've done a few on 4th Gens and they were MUCH easier.
SS_CTS-V is offline   Reply With Quote
Old 03-03-2023, 01:09 PM   #6
bottletalk
does jre use the crush washer? that's the weak point.
rather do my own work....hear what ur saying though.
Old 03-03-2023, 02:11 PM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
GM uses crush sleeves in a ton of diffs. I take it you have seen a lot of failures? I know it makes me not want to mess with a diff that is not leaking bad or making noise. Where do you even get the correct spacers to use in place of the crush sleeve?
Old 03-03-2023, 02:28 PM   #8
bottletalk
https://nitro-gear.com/nitro-gear-ax...id-spacer.html
https://www.yukongear.com/shop/sk-csgm8-5
it's proven that the crush sleeve moves on high torque applications, once it moves your bearing preload changes as well as your pinion depth which effects your ring backlash.
ask your gear manufacturer of choice for a solid pinion spacer or a crush sleeve eliminator for your diff. they are common items.
Old 03-03-2023, 03:09 PM   #9
bottletalk
https://youtu.be/5oALDmW5txY
https://youtu.be/iZInF95qHX8
I repair CNC machines and process automation systems for a living, haven't worked on a ton of diffs but I have seen my share of gear boxes and the gear boxes that use crush sleeves on our machines have to be changed to solid spacers or accurate consistency will not be met....talking +/- .0002" accuracy. sure it's not a car but the same principles apply. mechanical accuracy=max strength, long life with minimal failures.
Old 03-04-2023, 05:36 AM   #10
CamaroCracka
Thanks Bottle. Hopefully they make them for the ZL1 diff.
Old 04-06-2023, 02:49 PM   #11
SS_CTS-V
Honestly I'm not sure. You'd have to contact JRE and ask. That said, I don't have a ton of HP/TQ in my car so I can't give an opinion there. BUT after a few miles w/ the 4.11 and TruTrack diff, I love this setup.
