Old 03-07-2023, 01:08 PM   #1
UnbecomingTV
Drives: Camaro Gen5 2009
Missfiring V6 out of nowhere
Hey guys,
My Camaro V6 (118.000Km) started missfiring out of nowhere. First on Piston 1 with the Code P0301 and after waiting 30min and deleting the code. Everything went fine for 15km. And then it started missfiring on Piston 4 with the code P0304. Both times the cel went on. but on the second time it solved itself.
Do you guys have an idea why, could the bad weather have an affect? Drove thru an pretty heavy snow storm
Thanks
UnbecomingTV is offline   Reply With Quote
Old 03-07-2023, 01:50 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Changed the timing chain ever? If not, maybe pop off the valve covers and check the timing chain, could be loose (pull on the chain where it's accessible between the camshafts, should be taut). Another issue I've seen on a few LLTs is the reluctor wheel slipping a bit on the crankshaft and throwing off timing. Lack of fuel or spark can also create a misfire event.
KillboyPowerhead is offline   Reply With Quote
Old 03-09-2023, 09:47 AM   #3
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
Could be one (or a combination) of many reasons for misfires. I always start with the coils and plugs. Swapping coils to see if the code follows the coil, then checking the plugs for any wear indication. After that, it turns into a seek-and-find.
I also may run some gas cleaner if I suspect that the issue may be bad gas.
ElderJ is offline   Reply With Quote
