Old 03-12-2023, 03:47 AM   #1
ACEPA
3 Camaro man!
ACEPA's Avatar
Drives: Camaro 2.0 T
Battery has been flat four years
Due to COVID my 2015 SS
ACEPA is offline   Reply With Quote
Old 03-12-2023, 04:50 AM   #2
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
If the battery has been empty 4 years, it will most likely need to be replaced.
Fill tank with new fuel.
Change oil.
Car may run a little poorly.
Windows must be recalibrate.
Old 03-13-2023, 04:38 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
If it's been dead that long, you might not get it to take a charge, maybe a partial. Just replace it and be done with it, and you won't have any issues.
Old 03-17-2023, 12:29 AM   #4
ACEPA
3 Camaro man!
ACEPA's Avatar
What are the chances the ECU is bad?
Old 03-17-2023, 06:47 AM   #5
bsn
Drives: 2013 ZL1
Replace the battery don't try to charge it, you can create a whole host of problems trying to start the car with a weak battery. As far as the ECU 4 years of sitting won't hurt it at all. Depending on how you left your fuel system expect it to run poorly until you get fresh fuel in it. I would add some Sea Foam or Techron to the old fuel.
bsn is offline   Reply With Quote
Old 03-17-2023, 07:26 AM   #6
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Pull the plugs and squirt a little oil in the cylinders
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 03-17-2023, 03:20 PM   #7
chevy pilot
Old 02-05-2025, 03:16 PM   #8
tilstad
Drives: 2011 SS / RS Convertible
4 years is too long in must cases to have a battery attached to a car, as it uses power even when sitting. Probably won't recharge either as it sulfates and won't take a charge. New Walmart battery is prob your lowest cost option.
tilstad is offline   Reply With Quote
