![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Wanted: Flowtie Grille Emblem
Part #23468210 ![]() Thank You -Chad
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather |
I have a complete grille
Here we go!!!
Unless you have the corresponding grill for the flowtie, just buying the emblem won't work. The grill is solid behind the standard emblem. You could make your own like I did. Perfect no, but it flows air and still cool looking.
![]() Drives: Chevy Camaro, GMC Sierra Carbon Join Date: Mar 2023
what are these worth now-a-days?
#6 | |
The Flowtie mounts via a backing plate that is shaped like a Bowtie with the center hollowed out. Pic below. Unfortunately for me, when I traded in my '14, the Flowtie and Heritage grille went with the car. I don't have many regrets in life but not swapping in my modded OE Bowtie for the authentic Flowtie is one of them ![]() I am looking to do the Flowtie on my '22. I already installed the old modded '14 Bowtie, but I want the real one. I looked at the Gen6 ZL1 Flowtie and it is slightly bigger (Edit: I believe I was wrong on this) and it is much thinner which would make mounting more difficult. Flowtie on Heritage
"KEEP THE FAITH"-Fbodfather Last edited by cdb95z28; 04-20-2023 at 01:20 AM. |
#7 |
My current '22 SS 1LE with that moddedOE '14 SS 1LE Bowtie
Inner edge is a little rough from the plastic removal. I desire the Z Flowtie because it is very smooth there.
#8 |
![]() Drives: 15 Z28. 14 ZL1 Join Date: May 2020
#9 |
Update:
Since finding a Gen5 Z/28 Flowtie is a long shot, I decided to try to make one from a Gen6 ZL1 upper grille. This upper grille has an integrated Flowtie. By chance there was a gentleman (Thanks willzilla) selling a used Gen6 ZL1 upper grille on the camaro6 forums. I cut away the Flowtie base from the grille and shaped it so it would fit nice against my '22 SS 1LE grille. I wanted it to look seemless and like GM would have mounted it. A few optimized notches to match the SS grille, a bit of epoxy to fill in the cut areas where it was originally part of the ZL1 grille, some wet sanding and new way to mount it along with fresh matte black paint brought it all together. Fun fact. In order to do what I wanted to on the Flowtie base, I had to separate it from chrome part of the Flowtie. On the back of the Gen6 ZL1 chrome Flowtie is a #, 23468210. That is the same # as the 14-15 Z/28 Flowtie part #. I believe that GM copied the shape and design of the Z/28's Flowtie for the Gen6 Flowtie . I think GM used that # as a casting/mold # for the Gen6 application. A Gen5 Z/28 connection to the Gen6 ZL1! ![]()
#10 |
Big John
Drives: Wife 2013 Camaro 2SSRS / ME? Join Date: Mar 2012
Just picked up a brand new one off of EBay.
They’re still out there just gotta be at the right place at the right time. I’m looking for a new grille if anyone knows where one is at part number 23468208 Thank you John |
