![]() Drives: 2015 Camaro 2SS/RS Join Date: Jan 2007
TruTrac Gear Oil
What brand is everyone using?
"Eaton recommends a petroleum/mineral based GL-5 80W90 gear oil for all Truetrac Differentials. Do not use Synthetic gear oil or friction modifiers"
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune Kooks LT/HFC/Xpipe/NPP Mufflers 4:10's, Trutrac Solid Cradle Bushings, BMR Toe and Trailing arms |
![]() ![]() ![]() Drives: 2011 2SS/RS Join Date: Feb 2016
The few people i know with the tru-trac just use the parts store non synthetic. I love my amsoil but they are only synthetic. When i go the swap, itl probably be top tear non synthetic by mobil.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
Hardcore Gearhead
Nothing special is needed with an Eaton Truetrac carrier. Being a helical LSD it doesn't have the friction modifier requirement a clutch style of LSD does so any good GL-5 lube will work fine. No need to use synthetic as a good petroleum 80W-90 will work perfectly. I personally use Valvoline or NAPA (same), nothing special is required.
Mike
2013 2SS/RS |
![]() Drives: 2015 1SS 1LE Join Date: Sep 2015
I use Lucas or Valvoline, whatever's available on the shelf at the parts store that day.
![]() ![]() Drives: 700 rwhp 2010 SS Join Date: Sep 2010
I used Valvoline basic 80w-90 in mine.
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
https://torcousa.com/products/rgo-racing-gear-oil
Run this in my Camaro and Pick up both True Trac equipped, I run the thicker weight in the truck.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
#7 |
Thanks All. I settled on Lucas Oil SAE 80W-90 Gear Oil (LUC10043)
2015 2SS/RS 6spd
