Old 03-19-2023, 08:55 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Aux pump + zl1 pump, no FPCM tune
As some you all know my car is done after an 18 month hiatus. Before I take delivery I want to make sure the tune is 100%. The hp being put down is not anywhere near what others have put down in similar builds. My assumption is that the fpcm is not adjusted to demand the fuel that is needs. I was told the duty cycle is 96% on the pumps, but still have a lot of injector left. Could that be the cause of having low power?
Power 700/597
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 03-20-2023, 07:17 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
IIRC, the stock FPCM will fight the aux pump by pulling back on the main pump if it hasn't been told otherwise.
Old 03-20-2023, 08:28 AM   #3
RupertPupkin
Ty.
730whp: 630Trq
Old 03-21-2023, 11:18 AM   #4
eLeSthree
Drives: 2011 Camaro SS 6sp
If you have plenty of injector, and a repeatable 65+psi of fuel pressure (ask tuner), then the reason for the low power would be the lack of airflow. That small blower is already blowing hot air and you're only getting 9-10psi. That means the motor is ready for more, and the blower is spent. I think this was Ted's point earlier about the small blower being a governor on the larger cube motor. #ITNEEDSAYSI
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 03-26-2023, 03:57 PM   #5
Surfdog SS
Surfdog SS's Avatar
Drives: 2015 SS Black/Black
Seems low to me since your built, but I don't know much. I'm currently at 600 on 93, cam, zl1 pump and bap, 1000cc injectors @ 50%, my fpcm is programmed. I loose some pressure at e50, time for an aux pump and take the restrictor plate out. I'm hoping to be around 700 on e85 next go around
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Surfdog SS is offline   Reply With Quote
Old 03-26-2023, 05:31 PM   #6
RupertPupkin
Everything checked out. Final number 730/630. Blower was maxxed. Definitely feels just as fast if not faster.
730whp: 630Trq
Old 03-26-2023, 06:07 PM   #7
Surfdog SS
Surfdog SS's Avatar
That's awesome man glad you got it back on the road
Old 03-26-2023, 10:26 PM   #8
RupertPupkin
Ty. Already want to go bigger.
730whp: 630Trq
Old 03-27-2023, 06:32 PM   #9
Surfdog SS
Surfdog SS's Avatar
I'm in the market for an aux pump kit if you do
