Catch Can Setup - Valve Covers
Hi all..I am setting up a new catch can, however I am running into an issue. Awhile back, a performance shop vented my valve covers. So now I have brass fittings on each valve cover with hoses to breathe.
The catch can I am setting up is from Motion Raceworks, and I'm setting it up from the valley to the nipple on the intake manifold as normal. The issue is that I do not know what to do about these open valve covers. Should I plug them? I do not know why they are open or why they did that, so I can't answer why that is. I just need to fix or utilize it. Any help is appreciated! Thanks!
2010 Inferno Orange Metallic 2SS/RS - 6 Speed Manual
-BTR Stage 4 Cam, ID850 Injectors, E-85 Tuned, Corsa Xtreme Exhaust , Kooks 1 7/8 Headers, Melling Performance Oil Pump, ATI Super Damper, BMR Suspension: Sway Bars, Trailing Arms, 1” Lowering Springs, Differential Bushings, Rx Ported and Polished Throttle Body, VIS Racing Carbon Fiber Hood, Custom Painted - Body Kit, Entire Vehicle, ZL1 Addons Wicker Bill, MRR 20” Wheels, Powerstop Brakes, Koni SRT.T Shocks and Struts ![]() |
![]() Drives: 2014 SS 1LE Join Date: Apr 2014
Need a little more info on the motion catch can you are planning on using.
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Pictures may help
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
I don’t think vented valve covers is a good thing.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
#5 | |
Motion Raceworks Top Loader Billet Oil Catch Can
#6 |
Just imagine the valve covers with brass fittings to allow air to escape. I can’t seem to get this to load photos but literally just fittings to allow air to escape and breathe. Not really much to see. But regardless I’m not sure why they are vented.
#7 |
Why so? I’m just wondering should I cap them off or leave them alone.
#8 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Is your car forced induction? Theres a lot of mods listed but I didn't see anything.
#9 |
Motion Race Works Catch Can
Here two pics of the Motion Race Works Catch Can. I’m waiting\saving money for a set MRW Valve Covers.
Orange Krush II
#10 | |
You can then connect the can how you mentioned in the 1st post I don't know how that can functions though so can't say for sure.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
You usually connect the passenger side valve cover to the air inlet on the intake tube by the throttle body. And in your case I would vent the drivers side valve cover with a breather. On mine I have the drivers side hooked up to the intake manifold but I think you said on yours you have the port on the valley cover which means you the pcv system under the valley cover hence it goes from the valley port to the intake manifold correct?
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
#12 |
Did you check the Motionworks web site? It says that can is for racing only and is not street legal.
#13 |
In a race application, both valve covers are connected to the catch can. This sounds like the can you have. The idea is under boost there is blowby that causes pressure in the crankcase. This pushes oil vapor into the can and relieves the crankcase pressure through the filter on the catch can. I believe those systems also use a vacuum pump that's driven off a belt.
I would not plug your valve covers. Any crankcase pressure would have nowhere to go except out your seals. There's other reasons to have fresh air entering the crankcase that you can probably search for beyond the scope we're talking about here. Other catch cans like the Mighty Mouse use the vacuum to help pull in crankcase vapors into their can, then if under boost, the crankcase pressure will exit the catch can through the vent filter on the catch can. The filter has a valve that prevents air getting pulled the wrong way through the filter. Correct me if I have stuff wrong here guys. Last edited by FasNuf; 03-23-2023 at 07:05 PM. |
#14 |
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
