Old 03-22-2023, 02:47 PM   #1
Tjss
Drives: Chevy Camaro
Car throwing codes
Hi! I’m new to the forum and hoping someone could help me out. I have a 2015 Camaro SS. The car has ported heads through TSP, Stage 4 TSP cam, 1000cc injectors, Cold air intake, Longtube headers, Catless exhaust, no resonator and carven r mufflers (listing every detail) and a dyno tune.
Here recently the car has been throwing a P0106 code along with a stabilitrack service message. The car will sit at idle and the service stabilitrack message will appear, the minute you tap the throttle to 1500 or so rpm’s, it goes away. Let it idle for about 15-20 seconds. Stabilitrack comes back on. I have checked all grounds, checked for vacuum leaks, replaced the map sensor. I am confused on what this is and am hoping someone could lead me to the right answer!
Car has 11,000 miles! Got all the work done back in 2021.I first noticed this back in February of 2022. The car was tuned in April of 2021 ran perfect. Back in February of 2022 was coming down a ramp off of the highway, and went into reduced power mode. Shut the car off for about 5 min. Went away and I parked it until the summer of 2022. Always had the check engine light but the car never did it all summer. Now here we are in 2023, and it’s doing the same thing again. Really confused.
Thanks!
Tjss is offline   Reply With Quote
Old 03-24-2023, 05:54 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The most common cause of Stabilitrack error messages is low voltage. Those pesky built-in test circuits report false negatives when DC voltage dips, even momentarily.
So, after checking battery terminals and chassis grounds, the next step is always to get a nice new battery.
Rock-It Man is offline   Reply With Quote
Old 03-24-2023, 09:10 PM   #3
gtstorey
There are diagnostic steps for the code in the service manual. It will narrow it down to what is wrong.
Certain engine codes will also cause the stabilitrak to throw a code. I don’t know if the p0106 is one of those.
Old 03-27-2023, 05:46 PM   #4
Tjss
Okay! Thanks for the tips! I will try the battery and get back with y’all. I appreciate the help!
Old 03-30-2023, 03:21 PM   #5
Tjss
Put a new battery on, nothing has changed, decided to take it to a shop since tuner won’t look at it, will keep this post updated incase someone else runs into this exact problem.
