Old 03-22-2023, 10:30 PM   #1
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
Changed Pulley Sizes - Do I need a tune?
My current tune was for a stock ZL1 lower pulley and a 2.85 upper pulley. I ran a single belt setup with that.
I converted to a 3 belt setup with a +10% lower and a 2.55 upper.
Do I need to get re-tuned?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 03-22-2023, 11:55 PM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I'm pretty sure you'll want to, but it won't be drastic so you can drive it to your tuner. Just keep the boost down. If you have a wideband, all the better.
FasNuf is offline   Reply With Quote
Old 03-23-2023, 07:43 AM   #3
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Thanks. This is a new tuner for me, and it would be a dyno tune. Won’t be cheap, because he wants to start from a fresh base tune. He did my dyno run before this upgrade so at least I will be able to see what difference the pulleys made.
