Old 03-27-2023, 05:59 PM   #1
Armyavi8r
Armyavi8r's Avatar
Drives: 2010 Camaro 2SS/RS A6
2010 SS A6 Buzzing When Upshifting
Hi all! My 2010 Camaro SS A6 is making a buzzing noise as it upshifts. More noticeable when cold especially from 1st thru 4th gears. Shifts normal otherwise; no grinding, no slipping. Fluid was normal. 6L80 with a 36-3800 stall (added 17k miles ago during cam upgrade). Anyone experience this? TIA!
2010 2SS/RS A6. GPI SS3 VVT Cam, 228/246 / AFM Delete / Circle D 4C 36-3800 Stall / Stainless Works LTHs, High Flow Cats, X-pipe, Borla Pro XS Mufflers and Quad Tips / Vararam CAI / Soler 95mm PTB / AAM 3.91 gear / GPI Ported Heads / GPI Ported Rod Mod Intake Manifold/ Smith Bros. Trunnions / GPI 5/16" hardened push rods, 7.425"/ Chevrolet Racing Lifters / Melling 10355 Oil Pump / Powermaster XS Torque Starter / Derale Xmsn Cooler / 1LE Suspension Upgrade System / BMR Strut Tower Brace, Trailing Arms and Toe Rods / Powerbond 25% UDP / Mishimoto catch can / iDatalink Maestro.
Armyavi8r is offline   Reply With Quote
Old 03-27-2023, 07:45 PM   #2
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: sometimes
Usually there are 2 things to go back and check with a converter swap.
1. The fluid level needs to be checked when warm because no matter how hard a person tries to fill the converter before installing it, the process can still lose some and the converter is just not ever really full after install. The prefill just prevents dry startups from trashing the new internal parts. The A6 trans has a plug where the dip stick would NORMALLY be There is no dip stick on the Camaro from the factory like the old days.
2. The other thing is it probably needs to have a Trans tune to get the line pressures back up to allow the solenoids to build up pressure. A GOOD tuner would know this. Too low and the transmission act it is low on fluid. Too high and the seals will blow=trashing the transmission.
PoleCat2SSRS2010 is offline   Reply With Quote
