03-28-2023, 09:50 AM | #1 |
Drives: 700 rwhp 2010 SS Join Date: Sep 2010
Fuel filter replacement with e85?
How long do you guys go on average between changing your fuel filters? I have a fore innovations triple pump set up with an inline fuel filter (I believe its a microglass ssd filter) and run E85. Obviously there are a number of variables, but I was just curious to see what the "Rule of thumb" was in regards to this especially with e85 as I'm pretty new to the world of E.
03-28-2023, 11:55 AM | #2 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
My understanding is that E is dirtier. I change mine every 2-years but should every year. My fuel strainers on the pumps themselves needed swapping also. I would presume every 2-3 years on those. When I spoke with Fore, they instructed me since E was so caustic that the pumps should be swapped out annually. Pfftt!
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-28-2023, 12:24 PM | #3 | |
03-28-2023, 01:18 PM | #4 | |
Drives: 2014 SS 1LE Join Date: Apr 2014
I haven't had my pumps rebuilt/replaced but i did change the switching order of my pumps since i know the primary had many more hours of use over the secondary/hobbs activated pump.
03-28-2023, 01:18 PM | #5 |
"They" say to run a tank of 91/93 each month since it has detergents and lubricants in it (to compensate running E). Awhile back, I had a LPE (CTS-V twin fuel pump) in and ran it for 4-5 years, no issues whatsoever. When I did swap over to triple Fores, I did have an issue after a while (maybe 2-3 years) in which on random runs, I could be running lean, other runs just fine. Pulled my hair out trying to figure out if it was the tune or hardware. After I swapped the triples out with the 525 Hellcat pumps, all was good again - so, I'm betting it was the pumps.
03-28-2023, 01:21 PM | #6 | |
03-28-2023, 01:42 PM | #7 |
This is what I run on mine. Only been on a year, but is stainless steel. Comes in various micron ratings.
Just more options to consider - Cheers https://deatschwerks.com/collections/filtration |
