Old 01-19-2010, 04:48 AM   #1
SS Power
SS Power's Avatar
Drives: Camaro SS in white
SLP Exhaust pipe - need help!
Hi Camaro lovers,
I want to change the original exhaust pipe system of my 2010 Camaro SS (Automatic). I want to put a realy loud one on it. I was thinking in a exhaust pipe from SLP - Part Number 30214. I want it to sound like the gray Camaro on the first video.
http://www.slponline.com/view_product.asp?P=30214
If I understand it right I have to add a SLP LM II axle-back exhaust to it. Can I only use the Part number they say - "#31212" or can I also change it for part number - "#31211"?
Part Number 31212 (with mufflers)
http://www.slponline.com/view_product.asp?P=31212
Part number 31211 (no mufflers)
http://www.slponline.com/view_product.asp?P=31211
Thanks for Help!!!
SS Power is offline   Reply With Quote
Old 01-19-2010, 06:13 AM   #2
infernoinandout
infernoinandout's Avatar
Drives: 2010 camaross/rs
Go local
If you want load with no mufflers just take it to a local muffler shop and put straight pipes and the tips from the factory setup, hell of a lot faster and cheaper.
infernoinandout is offline   Reply With Quote
Old 01-19-2010, 10:02 AM   #3
GangGreen
GangGreen's Avatar
Drives: Victory Red LT RS Born:3/3/09
I agree with the above post.
GangGreen is offline   Reply With Quote
Old 01-19-2010, 11:53 AM   #4
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
I agree with the above, above.......................
THUMPER20X is offline   Reply With Quote
Old 01-19-2010, 11:57 AM   #5
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Originally Posted by SS Power View Post
Hi Camaro lovers,
Thanks for Help!!!
yes you can.
KKreme15 is offline   Reply With Quote
Old 01-19-2010, 02:32 PM   #6
brAnd7onX
brAnd7onX's Avatar
Drives: 2012 1SS IOM
If you want it loud then why are you going with Loudmouth II?? Loudmouth I is a lot louder than II. But Loudmouth I is basically a muffler delete so like the above post said, just get straight pipes and weld the tips.
brAnd7onX is offline   Reply With Quote
Old 01-19-2010, 02:42 PM   #7
SS Power
SS Power's Avatar
Do I need to weld the Loud Mouth II Pipes too or can I just conect them and screw them on?
Old 01-19-2010, 03:04 PM   #8
brAnd7onX
brAnd7onX's Avatar
If you buy just the LMII axle back u have to weld it to the existing cat-back but if you get the full system with the headers and x-pipe then its all bolt on i believe.
Old 01-19-2010, 06:35 PM   #9
SS Power
SS Power's Avatar
Perfect! I want to get the full thing - Header Package with the x crossover pipe and add the loud mouth to it. Will there be a big difference in the sound between Loud mouth 2 and loud mouth 1 if I change also the headers and the x pipe?
Thanks for the great help guys!
Old 01-19-2010, 06:45 PM   #10
Dre2216
Dre2216's Avatar
Drives: 1SS IOM M6
The LMII does not need to be welded on for a stand alone installation. It comes with clamps that attach it to the car and the existing attachment points. If you have access to a lift it is about a 45 min. job.
1SS/RS-6M-Inferno Orange
NKKV6J---2G1FS1EW4A9134727
SLP LM II
2/26 - Car Back From Dealer!
Dre2216 is offline   Reply With Quote
Old 01-19-2010, 07:16 PM   #11
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
If your running LT's and Hi-Flo cats and the complete 3" SLP set up i would go with the LM I which is also 3".....i beleive that the LM II is only available in 2 1/2"
FEN is offline   Reply With Quote
Old 01-19-2010, 07:35 PM   #12
SS Power
SS Power's Avatar
I spoke with my Chevrolet dealer today. He would install it for me. He only had one question about all the sensors that are attached at the exhaust pipe to measure the power flow, ect.. He needs to know if all of the measuring results are the same as by the standard exhaust system or if there are changes. If there are changes the car will show a red light at the dashboard telling me to check the engine because the car will think than that something is wrong. Can someone help me with that point?
Old 01-19-2010, 08:06 PM   #13
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
Hi Camaro lovers,
Thanks for Help!!!
I saw a silver camaro on the first video, the other was yellow
Then there is a gray camaro with a LM II and Header Pkg PN 30214 that looks like this:
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 01-19-2010, 10:24 PM   #14
petman
Proud IBM Owner
petman's Avatar
Drives: 2010 1SS-RS
SS Power, from what I have read on here, the O2 sensor light probably will show its code, and I don't know if the Chevy Dealer will Tune UR ECM to accept that, read more in these thread throughout forum and you'll see what folks are doing. most go to a speed shop for a dyno tune, and others get a handheld tuner... JMO
My Baby, 1SS/RS Auto
petman is offline   Reply With Quote
SLP Exhaust BlackRS/SS V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 8 02-27-2010 02:47 PM
SLP LT headers and crossover pipe - $200 off and flat rate $25 shipping @ PFYC.com Redshift V8 Bolt-Ons & Tunes 14 02-22-2010 03:34 PM
Anyone in Hampton Roads w/ SLP exhaust? chevyluv7 USA - Mid-Atlantic 3 01-14-2010 02:29 PM
1 3/4's vs 1 7/8's Headers brAnd7onX Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 01-11-2010 06:43 PM
SLP Loudmouth Exhaust BlackRS/SS USA - Northwest / Pacific Northwest 5 11-17-2009 02:04 AM
