04-07-2023, 06:33 AM | #1 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
AGP Endurance vs Race Intercooler for Street Use
Trying to find out if the Race cooler would be ok for street use here in the south?
Car is not a daily driver, but still want to be able to go for a long drive on a summer day without fear of cooling temps running too high. The car is an A6. Thanks! Brian |
04-07-2023, 08:09 AM | #2 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
For what it is worth, our summers in Indiana will get to the high 90's and sometimes peek a little above 100. I have the race intercooler with my kit and also have a BTR stage 2 turbo cam. I will drive mine on those hot sunny days and even use my air conditioning without issue. If your on the fence, talk to Kevin at AGP, he won't steer you wrong.
04-07-2023, 08:24 AM | #3 |
Thanks!
I am ready to place the order. Just a little concerned with the 6L80 and heat. I will most likely end up doing an upgrade for the trans cooler I guess I should talk to Kevin, what's the best way to reach him? PM here or by phone? Thanks! Brian |
04-07-2023, 11:13 AM | #4 |
I have always called his shop, you'll have to check the time difference between S.C. and Arizona. He is usually in about an hour after their open time. He is very knowledgeable and extremely helpful. You will enjoy the kit. I'm 60 and it made me smile like a kid again....enjoy.
04-08-2023, 05:52 PM | #5 |
Sucker Punch
Drives: 2013 Black ZL1, 2007 Silverado LTZ Join Date: Jul 2014
I have a factory trans cooler that sits in front of the A/C condenser does anyone know if the intercooler will fit without removing the trans cooler?
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
04-17-2023, 02:39 PM | #6 |
Decided to go with the race cooler, order has been placed!
Thanks @AGP for everything you guys do! Brian |
