Old 04-08-2023, 11:54 AM   #1
Surfdog SS
Surfdog SS's Avatar
Drives: 2015 SS Black/Black
Aftermarket fuel rail or factory fuel rail flip
I want to clean up my engine bay and was thinking about valve covers and fuel rails, or do the flip. I'm planning to stay with the factory intake manifold. Any advice would be appreciated.
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Surfdog SS is offline   Reply With Quote
Old 04-08-2023, 01:18 PM   #2
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
There's a lot of cool things people have done under the hood, so my advice would be to dig through the forum and find as many pictures as you can to get ideas on where you want to go with your build.
I went with Holley valve covers (black crinkle) to keep the coils in the stock location. I also have Holley EFI fuel rails and crossed the fuel line in the back.
Here's a couple angles to show how it looks.
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 04-08-2023, 02:20 PM   #3
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Here are a few pics of mine still in progress. Here is a cool thread to check out also. Ton of cool ideas here.
https://www.camaro5.com/forums/showthread.php?t=188393
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 04-08-2023, 07:15 PM   #4
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
To me the coils/ wires make the biggest mess. Clean those up and the stock fuel lines don't look so bad. I'm an aesthetic guy, so I changed mine to fuel rails, but the stock system is plenty capable.
joshnmn is offline   Reply With Quote
Old 04-08-2023, 07:16 PM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Old 04-10-2023, 04:58 PM   #6
Surfdog SS
Surfdog SS's Avatar
Attachment 1124692
Attachment 1124694
Did you use a t in the back off the passenger rail to feed both rails. Looks great!
Old 04-10-2023, 07:50 PM   #7
Bee
Bee's Avatar
Thanks! Yes, I used EAR-AT925106ERL on the passenger rail. I also went with PFTE lines instead of the stainless steel lines...it was a lot easier to work with and I haven't had any fuel odors. Although it was probably overkill, I also installed EAR-AT100199ERL at the T so I could keep a Schrader valve in the system. This is the same one I used on the driver rail to mount the fuel pressure gauge.
Here's a better lit picture I took during the install.
Old 04-11-2023, 11:21 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here is a pic of mine before I did the LOD install. Stock manifold with the "clamshell" cover painted RJT and the stock fuel rail flip. I also have the Holley tall valve covers custom painted as well and Accel coil packs.
Old 04-13-2023, 10:50 AM   #9
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Here's mine.
Name:  New engine bay.jpg
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 04-14-2023, 06:24 AM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Start with fuel rail flip. If going aftermarket intake, build from there.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
