Old 04-08-2023, 01:02 PM   #1
caper
Drives: 2010 IOM 2ss/RS
ground wire location
I am aware of the one to the trans bolt from the DIY, is there another location that works well , and preferably easier to access? hot start issue continues and the location of the other one to the trans bolt isnt workable for me. any other . i know on the gen6 theres one they use in the engine bay to the body but i dont think the same location is available to us. thanks!
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 04-08-2023, 01:51 PM   #2
gtstorey
Any of the trans bolts should be electrically the same as long as you confirm no gasket surface in between the connection and what ever load needs to be grounded.
Old 04-08-2023, 02:26 PM   #3
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
I ran a ground cable from the location right behind the alternator, there is a place on the block just below the head that has a small ground wire already . Then ran it to the ground location on the frame down across from the steering shaft knuckle. This is on a 2010 ss. I'll try to get some pics up later.
https://www.amazon.com/photos/shared...-mVJQ9UbWm_9oZ
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
Pkeen is online now   Reply With Quote
Old 04-08-2023, 03:13 PM   #4
Pkeen
Pkeen's Avatar
Click on that link to see pics , also make sure you clean all your ground points to bare metal ! Hope this helps!
Old 05-29-2023, 01:11 AM   #5
caper
just wanted to come back and say THANK YOU!!! this - after years of having this issue, and trying everything and anything - was finally the one that fixed it.
Old 05-29-2023, 10:08 AM   #6
Pkeen
Pkeen's Avatar
You are welcome sir and glad I could help!
Old 06-12-2023, 06:48 PM   #7
SILVERHAWK
SILVERHAWK's Avatar
Drives: 2011 2SS/RS, '22 Silverado Z71
I put in 3 grounds using 4 gauge wire. Battery....engine to frame and transmission to body. I am going to fall a little short of saying it's 100% fixed maybe 95%, but it's pretty darn good so far.
SILVERHAWK is offline   Reply With Quote
