Old 04-09-2023, 10:58 AM   #1
spyderbuddy
PO Code 2099
any one have a run in with this code
everything checks with a code reader, All O2 sensor seem to be working
Old 04-09-2023, 12:41 PM   #2
gtstorey
Service manual says
Exhaust leak
Low fuel pressure
Engine vacuum leaks
Fuel contamination
Lean fuel injectors
Says it isn’t o2 sensor without other codes
Basically engine is running lean during 17-65% load and trims can’t correct enough.
Old 04-09-2023, 01:22 PM   #3
spyderbuddy
Originally Posted by gtstorey View Post
Service manual says
Exhaust leak
Low fuel pressure
Engine vacuum leaks
Fuel contamination
Lean fuel injectors
Basically engine is running lean during 17-65% load and trims can correct enough.
That's different?
thanks
