![]() Drives: 2011 Chevrolet Camaro Join Date: Mar 2023
Does anyone know what this plug is or where it goes? It’s on the passenger side near the o2 sensor. I’m having misfires on all cylinders on the passenger side. The o2 sensors are connected and working fine.
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Sorry. I have mine on a lift right now and don't see anything similar.
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
A/C compressor plug
Impressive how anyone could get it way back there.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
Oh really? Interesting that it’s there. Well I’ll take a look at it and see how it’s supposed to be routed. Thank you so much for the information! That helps me a lot.
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I was thinking purge solenoid.
