Old 04-14-2023, 11:12 AM   #1
ADM PERFORMANCE
Drives: Anything I want
Summer is coming -Pics of Largest Heat exchanger
If you have not seen this ,its got to be a game changer
ADM PERFORMANCE is offline   Reply With Quote
Old 04-14-2023, 03:01 PM   #2
FastMatt12
Drives: Camaro SS
??? any more details? This for a Gen 5 ZL1? will it work on a Gen 5 SS with a Magnason? would it be a Upgrade for the Magnason HE?
FastMatt12 is offline   Reply With Quote
Old 04-14-2023, 03:19 PM   #3
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
dont leave us hanging. what car is that from. come on spit out the details
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 04-15-2023, 09:06 PM   #4
ADM PERFORMANCE
Well it fits the 5th gen only
All I know is it fits the 5th gen only. It uses factory zl1 hoses routing and its huge.
Old 04-15-2023, 09:19 PM   #5
Little Walter
Drives: ZL1
Would be interested in knowing if this has any effect on the radiator/ engine cooling being behind it.
Little Walter is offline   Reply With Quote
Old 04-15-2023, 09:52 PM   #6
tartagliazl1
Is it direct bolt on? Or do we have to fabricate brackets. Why so secret?
Old 04-16-2023, 06:22 PM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Old 04-17-2023, 09:59 AM   #8
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
I would say this is a non issue. My daily driver in the Texas Heat has no cooling problems and Im running a 4" thick intercooler at 1325+rwhp at 25 lbs of boost.
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 04-18-2023, 09:11 AM   #9
Little Walter
Drives: ZL1
Thanks for informing me on this.
Old 04-21-2023, 06:06 AM   #10
ADM PERFORMANCE
Its a bolt in with brackets. It connects to factory hoses also. Ill see if I can get more info on it.
Old 05-09-2023, 07:36 PM   #11
tartagliazl1
So how’s that HX working? Anymore updates or info on it?
Old 07-23-2023, 02:48 PM   #12
tartagliazl1
So what’s the deal with this heat exchanger? You went silent on it, did it not work out?
