Old 04-18-2023, 03:21 PM   #1
Rob-1SS
Drives: Chevy Camaro 1SS
Weird misfire problem
So I've been having an issue with some cylinders not firing particularly 3, 5, 7. I put in new spark plugs (twice) and same issue. I swapped ignition coils and tried some new ones and wires. Same issue. I removed and cleaned the injectors and didn't plug in cylinder number 1 all the way however when I turned it on cylinders 7 and 5 were firing and 1 and 3 were not. I then plugged injector 1 back in and unplugged cylinder 3 and cylinder 1 and five were firing. I'm really not sure what this is possibly wiring? ECM? Battery test great. I am in a state of confusion and rage.
What I'm running:
1SS
Cam (forget the size)
LT
Magnuson 2650 (6lbs boost) has been tuned.
ZL1 fuel Pump
Rob-1SS is offline   Reply With Quote
Old 04-18-2023, 04:32 PM   #2
Rob-1SS
Also, no codes and o2 and MAF sensors have been replaced. One thing I noticed was the battery's negative terminal was a little loose. I've tightened it but the problem persists.
Old 04-18-2023, 04:41 PM   #3
gtstorey
Sounds like a wiring issue. When you say you are plugging and unplugging injectors and this makes it fire, do you mean it runs on those cylinders or the plugs actually spark.
Old 04-18-2023, 05:31 PM   #4
Rob-1SS
No sparks. Normally right now cylinders 3,5,7 won't fire. If I unplug the fuel injector to number 1 then cylinder 5 and 7 fire. If I plug them all in and unplug number 3 cylinders 1 and 5 (I think it was 5, that or 7) fire up. I'm not going to rule out the supernatural just yet either.
Old 04-19-2023, 08:58 AM   #5
gtstorey
Still sounds like a wiring issue or an ECM. And by wiring, I'm including grounding issues. And by ECM, I'm including problems within the ECM with it's grounding drivers/bus.
But in particular it sounds like a short between the injector and coil wirings so that when injectors are plugged in, it's "stealing" the signal for the coil to fire.
Or you just have a loose connection/broken wires that all of this plugging and unplugging causes to make contact.
Old 04-19-2023, 11:20 AM   #6
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Still sounds like a wiring issue or an ECM. And buy wiring, I'm including grounding issues. And by ECM, I'm including problems within the ECM with it's grounding drivers/bus.
Exactly what I was gonna say, you’ve got wiring/ground issues somewhere.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 04-19-2023, 12:24 PM   #7
Rob-1SS
Thanks, thats what I'm thinking to, wiring or ECM. I'll be getting some needle nose probes (ones i have are too big) for my meter today but I work nights so I'll be getting up early and spending my off time messing with this lol.
Old 04-19-2023, 05:40 PM   #8
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Here are the injector & 1-3-5-7 coil diagrams if it helps any.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 04-19-2023, 05:51 PM   #9
Rob-1SS
Yes ty!
Old 04-19-2023, 06:01 PM   #10
gtstorey
I would start by tracing out/inspecting circuit 5291 since the injectors and coils have that in common.
Old 04-19-2023, 06:25 PM   #11
acutron42
acutron42's Avatar
Your welcome! Let us know what you find.
Old 04-20-2023, 06:34 AM   #12
acutron42
acutron42's Avatar
Start with the J113 connector. When I click on it the whole circuit lights up all of your problem areas. I will try to get some full pages posted @ work today.
Old 04-20-2023, 07:12 PM   #13
Rob-1SS
Thanks again. Didn't find anything today but I'll try again over the weekend. If I still can't figure it out I'm taking it to a friend's repair shop Monday.
Old 04-24-2023, 11:05 PM   #14
Rob-1SS
Gave up, it's at a friend's shop. I'll still post an update on what they find in case anyone else has a similar issue in the future.
