Old 04-24-2023, 11:08 PM   #1
Rowland2004
Drives: 2013 ZL1
e85 Timing Question
New to this platform and had the car remote tuned. Car runs great but had a question on the timing.
Timing up top is hitting 31 degrees @ 6800rpm
I have had many other platforms running E and haven't had timing close to that high on them. So just wanted to check with others before putting some fun miles on the car.
13 ZL1 SBE
Mods
BTR stg 3 cam
headers with full exhaust
1050x injectors
HX Ron Davis
Billet SC Brick
DSX Aux fuel
2.5 upper
10% ATI lower 12.5lbs
Rowland2004 is offline   Reply With Quote
Old 04-25-2023, 08:17 AM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
If your timing on E is too high, you'll shoot past the best torque and actually lose power before detonation. I'd be more concerned what he did for timing on the pump gas timing.
FasNuf is offline   Reply With Quote
Old 04-25-2023, 07:01 PM   #3
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
Seems to be alot of timing for sure.
Usually a tuner would add timing on the ethanol content tables .Example at 60%E add 6 degrees of timing at X amount of load and RPM. Unless you don't have a flex fuel sensor.
We had tried up to 28 degrees of timing on a stock bottom end LSA with 18 psi of boost,and it wasn't making more power. We didn't care if it would break or not. Now we are at 24 peak with a forged bottom end at 22 psi on the CTS-V.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 04-25-2023, 07:12 PM   #4
FasNuf
FasNuf's Avatar
What's the ethanol table look like?
I never subscribed to the Lo table matching the High table, seemed like a recipe for trouble if you ever got into knock, but I know some do it.
Old 04-25-2023, 07:30 PM   #5
FasNuf
FasNuf's Avatar
I guess another important thing to know is whether you're using a flex sensor or just strictly tuned to run your own E mix.
Old 04-25-2023, 08:14 PM   #6
Rowland2004
Drives: 2013 ZL1
I am thinking i will pull the base Hi and low back to around max 19 degrees to keep it around 24-25 max when it adds in the Flex timing.
I read great things about the tuner i used i just want to make sure im some what safe with the motor being SBE.
