Old 04-26-2023, 03:45 PM   #1
Tom C
Drives: 2014 Camaro SS
Driveline vibration at 34 mph
I have a 2014 SS auto and is all stock with 30k on it. The problem I am having is at 32-36 mph I am getting a vibration through the e-brake handle and it sounds like a faint helicopter sound. I have new tires that have been road force balanced twice and the brakes have been checked. I took it to the dealership and they said the drive line/drive shaft looked good and gave it back to me. The rear end doesn't howl and the vibration and noise are intermittent. Also if while driving and I pull up on the e-brake handle sometimes there is a loud pop. I'm not locking up the rear tires just slowing the car down a little. Any help is appreciated.
Tom C is offline   Reply With Quote
Old 04-26-2023, 03:57 PM   #2
gtstorey
Did it do it before the new tires?
Old 04-26-2023, 07:23 PM   #3
Tom C
Yes it did but the dealer insested it was the tires...so $750 later it still does it.
Old 04-26-2023, 08:25 PM   #4
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
They said the brakes are fine but did they take rotors off and check the E Brake shoes? I'd start there and if everything checks out I think I would back the shoes way off and try it.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 04-27-2023, 01:22 PM   #5
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
34 MPH is pretty slow for a typical driveline vibration. Not impossible but imbalance is centrifugal force that increases at the square of the driveline RPM. That's why you typically don't get DL vibrations until you reach higher RPM/road speeds.
These cars have had known center bearing issues though. If the bearing / rubber were bad enough, it could produce a vibration at this speed.
Moto-Mojo is online now   Reply With Quote
Old 04-27-2023, 02:27 PM   #6
Joe.G
Joe.G's Avatar
Center bearing going out could also cause EBrake handle /console to vibrate.
Old 04-27-2023, 03:27 PM   #7
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
After the loud pop, does it slow the car down or can you feel the vibration after the pop?
Car Nation Videos is offline   Reply With Quote
