01-19-2010, 04:25 PM | #1 |
Drives: Summit White 2SS RS Join Date: Dec 2009
What power on stock internals?
What is the general opinion of power limit on stock internals?
01-19-2010, 04:45 PM | #2 |
ive never got an answer but been seein people push 600whp to 650whp with no issues i know of
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
01-19-2010, 08:03 PM | #3 |
Drives: 2010 IOM Camaro Join Date: Nov 2009
01-19-2010, 08:57 PM | #4 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
It all depends on how hard you beat on it. If it's an occasional track car and you don't beat the hell out of it, it should last a very long time, if it's tuned well. You can wear out a stock engine if you beat the hell out of it constantly.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
01-20-2010, 06:36 PM | #5 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
It all depends on your flux capacitor
01-20-2010, 06:58 PM | #6 |
The LS3 is a real strong motor, with minor upgrades to the internals you should get quite a long lifespan
01-20-2010, 07:03 PM | #7 |
Drives: 99z28 Join Date: Oct 2009
The internals are good for high hp just replace the rod bolts and your good .
99 z28 a3 346ci .Motor by FUTRAL, Suspension by MADMAN 1.36 60ft 10.06 @ 132 175 hit old setup .
New setup 370ci with 88mm turbo in the works . 2010 inferno orange rs/ss 13.2 @ 108.4 stock http://getonitracing.net/ |
01-21-2010, 07:44 PM | #8 |
V8 Lounge member #2
A few Lsx engine builders and tuners have always told me that its actually the rod that goes first and not the rod bolts.
01-21-2010, 07:47 PM | #9 |
NOICE!!! ™
Still going strong
01-22-2010, 06:44 AM | #10 |
Drives: '88 Monte Carlo SS, '10 Camaro SS Join Date: Jan 2010
The weakest parts in our engines (in most engines) is the piston pin area. It is the point of highest pressure and once there is the slightest oblonging of the hole, it quickly self-destructs due to the jackhammering it recieves.
I've found the cars are 100% reliable (when properly tuned) at the 500-550hp at the tires level. After that you are playing with fire....may last a month, may last 5yrs, but you aren't going to get the 150k miles+ that you would with less power. Throw new pistons and rods in the engine and you're good to go for 700+ at the tires.
-Chris
'10 Camaro SS '88 Monte Carlo SS |
01-22-2010, 08:30 AM | #11 | |
I pushed 425wHP on my 2.4L 4cyl for 70K miles with no problem.. only reason went then was a vacumm line failure causing severe overboost.. This engine is stouter then ford 4.6L definately but they should of put in a lil stronger internals knowing we all going to hook up engine..
01-22-2010, 08:30 AM | #12 |
01-22-2010, 08:32 AM | #13 |
NOICE!!! ™
01-22-2010, 09:50 AM | #14 |
It isn't going to blow up the first time you put your foot down (as proven by Andro), but everytime you use the power it takes away from the life of the engine.
Andro, have you run your car at the track yet? Should be 140mph+ with that kind of power!!
-Chris
Similar Threads | ||||
starter gets no power... please help | zebra | General Automotive + Other Cars Discussion | 16 | 11-12-2009 10:37 PM |
ADM Performance Cold air intake makes 18rwhp and 18 tq over stock airbox | ADM PERFORMANCE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 129 | 11-10-2009 07:29 PM |
Why i think you cant do a Dyno in the same day | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 10-22-2009 07:37 PM |
Camaro L99 American Racing Headers (Catted) system with stock exhaust = +42rwhp | pharmd | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 43 | 07-25-2009 10:01 AM |
Camaro SS Questions. 500-600hp possible on stock internals? | Gone | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 36 | 04-22-2009 08:04 PM |
