04-28-2023, 06:58 AM | #1 |
Drives: 2010 SS M6 ABM Join Date: Mar 2015
Traction Control Issues Since Suspension Upgrade
Since my recent upgrade to a 1LE Suspension and going to a square set-up for tires/rims (20X10 w/275/40R20 all around), when I corner even kind of hard the Stability Track activates. It's quite aggravating. This will happen in the normal mode and in Competitive Driving Mode. I fear turning the traction control off because I don't know the limits of my cornering with the new set-up.
May questions are: - Why does the Traction Control activate, is there some type of G-force sensor that is causing it or what? - Is there a way to program this out? |
05-08-2023, 08:09 PM | #2 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Are the tires new? Is there something loose?
Can you data log to see which wheel is breaking loose to see why it’s turning on
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
05-15-2023, 03:24 PM | #3 | |
