Old 05-01-2023, 07:54 PM   #1
Husky429
Husky429's Avatar
Drives: 2011 Camaro 2SS/RS
3 Collapsed Lifters in 1,000 miles
I have a 2011 SS Auto L99 with DOD and AFM delete and a mild TSP cam. Had a lifter explode so I replaced the oil pump with a Mellings pump, new pickup tube, new timing chain, all new CHE rockers, Comp Cams lifters and a new TSP cam. 200 miles into the rebuild, another lifter collapsed and I replaced it with a drop in replacement from Comp. 200 miles later, I have ANOTHER lifter tick. What the heck is going on?
Husky429 is offline   Reply With Quote
Old 05-01-2023, 08:26 PM   #2
theflea42
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro
A long time ago, comp cams had a bad batch of valve springs. I bought a set of springs to match the comp cams camshaft I was putting in a 5.3 v8 for my s10. One of these springs broke, major engine damage after swallowing a valve. Started over with a brand new block, replaced just the one broken spring. Had two more springs break at two different times. The spring pieces got jammed up on both occasions to keep the valve from falling in, so no engine damage this time.
If you've had this many lifters go bad, I think I'd junk them all and replace with a new set. At least on the side of the engine where you're having the trouble.
theflea42 is offline   Reply With Quote
Old 05-01-2023, 09:00 PM   #3
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
You used junk lifters… the good ones are very well known on here, in a nutshell the GM caddy racing lifters are good all around, Johnson’s are really good for higher rpm/more high abuse, and there’s one or two others that make the cut as well. I’d run stock LS3/7 lifters in a cammed engine over comp stuff any day. I see you are new here, take some time and search the site and you will see distinct patterns on what works well and what is a gamble. If you aren’t revving to the moon stock GM LS3/7 stuff will very likely be fine.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 05-01-2023, 10:58 PM   #4
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
I've stayed away from Comp parts from the beginning. A local tuner told me they were having quality issues again...he didn't elaborate.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 05-01-2023, 11:00 PM   #5
Modernmusclecar
Yep..ls7 lifters in my build. Zero Comp anything. Good advice.
Old 05-01-2023, 11:03 PM   #6
Modernmusclecar
Call TSP and order all new valvetrain components. Your fine with your other upgrades .Get the Comp stuff out and go with TSP recommend parts. Lifter ...springs and push rods based on your cam
Old 05-02-2023, 12:34 AM   #7
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
+1
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-02-2023, 08:45 AM   #8
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Unfortunately it sounds like you may be a victim of "you get what you pay for". I went and took a peak at TSP's site, it looks like the Comp lifters are only $266 - that's even less than what a set of GM stock lifters cost! Great deal if they hold up, but I think you're finding that they don't.
I would consider a genuine GM LS7 lifter (not Delphi LS7-style) to be the minimum acceptable lifter for anything that runs .600+ lift and 400lbs of open spring pressure. Lifters are the most common component in the valvetrain to fail in my experience - and also the most difficult and costly to service. When I build out a package for our customers I default to the Chevy Performance - Racing lifters (aka Caddy, GMPP, P/N 88958689). These are another $130 over the cost of your standard genuine GM LS7 lifters (what all of your non-dod lifters are), but these are a substantially better quality part, better materials, better check ball mechanism, and much better reputation for coping with the rigors of higher lift cams, with more aggressive than stock lobes, more spring pressure, and more RPM.
Inexpensive lifters tend to create expensive failures. It's definitely a component worth investing in up front to save yourself a headache down the road.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 05-02-2023, 09:33 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
+ 2, Comp cams stuff is junk!! Stay away from anything they offer. Ever since they have been having issues with their stuff I have always stayed away. The LS7 lifters is what I have been running.
Old 05-02-2023, 09:39 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Great info here Andrew!! I unfortunately I have the Delphi LS7's in my build and so far have held up this far, 31k on them to this point. But ever since we have been talking about quality of lifters and see that these aren't one of the better ones, have quit driving the car as hard as I used to, just can't afford to swap them out yet for the Caddy lifters. Not even sure why my shop even used them in my build.
Old 05-03-2023, 01:11 AM   #11
Husky429
Husky429's Avatar
Thanks for the replies everyone! Bunch of good info. Unfortunately, COMP was recommended by the “old heads” in my family as the “go-to” so that’s what I went with.
Old 05-03-2023, 07:37 AM   #12
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Well, that's why you need to stay up on stuff for the LS engines. What USED to work on the old SBC and others from Comp was different than today's garbage. So, based on their "old" experience, they were simply not up to the minute. It's a shame too, as Comp used to provide decent stuff for a decent price. But these ain't the 80s and 90s no more. Putting in lifters should never be a crapshoot.
It's like having an old doctor that hasn't cracked a medical book in the last 30 years telling you how to treat your ailments. You may want to take their medical advice, but verify it with a second opinion before taking action.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 05-03-2023, 10:26 AM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Exactly this!! Back in the day, "used to be good". Not so much anymore. Heck, even Crane stuff used to be good, but I'm sure they even hadn't kept up with the times. Used to run their "hi-rev" lifters in my SBC 327..
Old 05-09-2023, 02:56 PM   #14
InFiD3ViL
InFiD3ViL's Avatar
I have been watching a lot of the Smeding Performance videos (That Engine Guy on YouTube) and they run the Gatorman link bar lifters on many of their builds, even up to 7k rpm. They run in the $450 range. These guys have some sick builds, so at that price point they have me very curious.
Very good lifter explanation video:
expensive, lifter, lifter tick
