Old 05-05-2023, 01:24 PM   #1
xdamxincx
Banned
Drives: zl1 blk
OIL COOLER OPTIONS ? ?
So ive got the trans out of the car and noticed a new oil leak .. looks like its coming out of the oil cooler.. im not really digging the design as it sits right next to my header... so i was wondering if any of yall had experience/recommendations with aftermarket oil cooler set ups..
xdamxincx is offline   Reply With Quote
Old 05-05-2023, 03:28 PM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Don't have a recommendation but I am familiar with the leak as that is very common on this car. The bolts get loose quite easily and its a tight fit even on my lift to retighten. They are only around 20 lbs so DONOT over tighten as its aluminum as you know and if you strip the bolts in the block you are screwed. I checked mine every year when I change the oil and it has never leaked after retightening.
ZMEnow is offline   Reply With Quote
Old 05-16-2023, 10:41 PM   #3
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: sometimes
Oil Cooler Options for the 5th Gen
It might be a long read but this is about as comprehensive for the 5 Gen as I could put together. Mine has been in service 2020. Hope this helps.
I need to mention that the lower grill itself will need clearance modifications if the cooler is mounted where mine is. This is done with removal of the front fascia, safety glasses and gloves and with the use of a hot knife and a small carbon fiber wheel in a small grinder or Dremel. It will require a lot of trial fitting. Take time, be patient, don't go savage and it can be done for a clean factory install look.
File Type: pdf 5th Gen Camaro Oil Cooler Options 05162023c.pdf (1,012.2 KB, 359 views)
PoleCat2SSRS2010 is offline   Reply With Quote
Old 06-11-2023, 11:15 PM   #4
xdamxincx
Banned
Drives: zl1 blk
Nice write up .. thanks for the info.
Old 06-13-2023, 01:49 AM   #5
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I know your super charged but I think our cars run at the same temps since you have the same stock cooler as a SS. So I currently use this one
https://www.mishimoto.com/chevrolet-...2010-2015.html
No it's not the best but it gets the job done. It stays in between 210-220 on a hot day (100*) in traffic and at high mph cruising. But if you start doing wot stuff it goes up and needs a few minutes to cool down. Other than that it's easy to install and you can reuse the lines if you ever need to go bigger like this one
https://www.improvedracing.com/mhx-2...il-cooler.html
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
