Figured out
Figured out
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
![]() ![]() Drives: 2013 1SS LS3 Join Date: Feb 2014
Thanks for clearing that up.
![]() Drives: 2010 Synergy Camaro Join Date: Apr 2023
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2LT/RS Join Date: Mar 2015
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can. |
#6 |
![]() Drives: 2010 Camaro 2SS/RS M6 Join Date: Jul 2021
LUCKY!!!!
#7 |
We've been ghosted!! lol.
#8 |
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
Are we talking women here?
That would explain the big box of nothing the rest of us know too. Welcome to the party pal.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
#9 | |
#10 | |
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
#11 |
Doesn't take much to amuse us car guys!! lol.
