Old 05-13-2023, 05:48 PM   #1
Jesspylle
Drives: 2013 zL1 camaro
Service suspension system
I just replaced my rear struts, hubs, and toe links now my dash is saying service suspension so I got the code read and it says ABS is this what’s causing the suspension to not work correctly?
Jesspylle is offline   Reply With Quote
Old 05-13-2023, 06:40 PM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Do you have magnetic ride still?
FasNuf is offline   Reply With Quote
Old 05-13-2023, 09:25 PM   #3
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
If you put mag struts back on did you have the battery disconnected when removing and putting the new struts in? Also when you replaced the Hub did you transfered the Speed sensor or did you put a new one on.
ZMEnow is offline   Reply With Quote
Old 05-15-2023, 10:46 AM   #4
Jesspylle
Yes but the front driver side feels like it’s riding rough
Old 05-15-2023, 10:48 AM   #5
Jesspylle
I didn’t disconnect the battery and I transferred the sensors
abs help, suspension help
