Old 05-14-2023, 03:33 PM   #1
Gstick
Drives: 2015 Camaro SS/RS 1LE
1LE differential fluid
I have misplaced my owners manual & searched here but can't find the part #.
Would someone Please give me the OEM GM part number for a 2015 1LE differential fluid & does it come with the LSD additive or do I need to buy that in a separate bottle?
Also, How much does the diff hold?
Thank You!
Gstick is offline   Reply With Quote
Old 05-14-2023, 03:55 PM   #2
Gstick
Found it!
75W90 GM# 89021677 1 quart
LSD additive GM# 1052358 2.6 oz
Old 05-16-2023, 06:10 PM   #3
Bo White
Bo White's Avatar
I run Mobil 1 75w90 straight.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 05-16-2023, 07:18 PM   #4
Silveradoss573
Banned
Drives: Camaro 1LE
#88862624 is what I used which already has the limited slip additive mixed in ready to go. 👍
Silveradoss573 is offline   Reply With Quote
Old 05-17-2023, 08:47 AM   #5
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
~2qts when empty. Typically, when I've done a "dump and fill" I usually need about 1.7qts to bring it back up to spec. "Up to spec" means that it just starts to run out the fill plug.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
