05-19-2023, 07:07 PM | #1 |
Drives: 2014 Chevrolet Camaro z28 Join Date: Mar 2021
starter replacement
I think my starter might be on its way out as its real hard slow cranking when hot. Called my local parts store and nobody has a replacement starter for this car
Can anyone point me in the direction to something thats in stock that they would use to replace their starter with? even gm was months out for a new starter |
05-19-2023, 08:56 PM | #2 |
Rock auto has a ac delco replacement number 12662757 if that would work
05-19-2023, 08:57 PM | #3 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
05-19-2023, 08:58 PM | #4 |
Beat me by a minute.
05-19-2023, 09:22 PM | #5 |
thanks buddy ill go ahead and order that one.
Just let the car sit for an hour while I was out. Car fired up no problem, so its just when it gets hot it gets lazy |
05-19-2023, 09:45 PM | #6 |
Drives: 2015 Camaro Z/28 #968 Silver Ice M Join Date: May 2019
Other Z owners had this issue. Try connecting a better ground. Start by cleaning your contacts on starter, battery and ground on body. If I find a link I’ll post it here. Good luck.
Current Cars:
2008 Honda CRV 2.0L 2015 Chevy Z/28 7.0L 2016 Chevy Tahoe 5.3L Past Cars: 1976 Chevy Malibu Classic 5.7L 1985 Chevy 2DR 4x4 Blazer 5.7L 1989 Chevy IROC-Z 5.7L 1995 Chevy 2DR 4x4 Tahoe 5.7L 2005 Chevy 4DR Tahoe 5.3L |
05-19-2023, 09:50 PM | #7 |
https://www.camaro5.com/forums/showthread.php?t=587039
Read this front to back. Good luck. Can’t get hotter than Houston Texas. It hot like a mofo here. So far it’s been good.
Current Cars:
05-20-2023, 07:20 AM | #8 |
Drives: 2015 z28 Black w/ac #645 Join Date: Jan 2017
How old is your battery. Do you have long tubes . I’ve got 30,000 miles on mine and starter is still good. Bought an AGM Odyssey 720 CCA after I got tired of the slow crank and hot or not it spins over.
Even bought a Powermaster starter #9509 still in box because battery did the trick. |
05-20-2023, 11:07 AM | #9 |
I replaced the battery last year
05-20-2023, 04:24 PM | #10 |
Miles ? The only reason I’m asking is there’s C6Zo6 owners getting close to 100 k miles on their starters and the ones that have replaced theirs because for the hot start issue are still having the issue . Adding another ground wire (if you haven’t already)could help. Hope the starter fixes it for ya for more fun miles driving this summer
05-26-2023, 11:26 AM | #11 |
Drives: Z/28 Join Date: Feb 2022
Thanks! I see this once in a while during the day. Never in the morning or cold start.
05-26-2023, 09:28 PM | #12 |
Yeah its starting to show the signs I believe are of a bad starter? When cranking when hot it will skip and just make a fast winding noise. Replacement starter and heat shield showed up today. Gives me an excuse to go over all the cabling as well as the car does have some parasitic loss to the battery somewhere.
05-26-2023, 10:24 PM | #13 | |
Drives: 2010 2SS/RS Join Date: Dec 2009
Starter
Orange Krush II
05-27-2023, 11:17 PM | #14 |
I replaced mine with high tourqe one from summit. When I pulled old one looked really scronny. I had slow start since I bought car i even e
Replaced ground wire in trunk. Now it starts supper quick and sounds way better than oem to me. I did it myself and it was pain in ass man I’ll tell you.
2015 Z28 #572 BLACK NO AC
