05-20-2023, 11:45 AM | #1 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
Mod bug
I hate it lol. Currently have the OEM kit pulley (110mm I think) on my 2650 with a 10% lower. Running around 10psi, dyno’d 621 on a mustang dyno. Figure 640-650 on a dynojet.
Mods in sig, currently running E65-E70 in warmer temps (>60F). Was thinking about getting a 103 TB and 103 adapter. Currently have a ported 95mm with a 95 to 87 adapter (stupid IMO). It’s a lot of coin to pay for another tune just for that change so I was thinking, could I push this a little more? Maybe a 95mm or 98mm pulley. Could drop down to E60 or lower if needed or do I need to wait until I do drop ins…. I guess the question is if my fuel system can keep up can the bottom end handle a little more, or am I playing with fire?
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
05-20-2023, 12:21 PM | #2 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Myself I have been thru a lot of changes and back to the drawing board a few times. Looking at your mods maybe consider meth and a good tune. The cam and heads are what wakes up these engines with supporting mods IMO. It’s a never ending saga IMO. If you do cam/heads then you might as well do pistons.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
05-20-2023, 12:47 PM | #3 | |
05-20-2023, 01:09 PM | #4 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Would respectfully say “No Way” to meth on stock pistons.
I’d definitely go for the 103mm TB and snout. Reducing inlet restriction will set you up for more success as you build out your car. Are you running a Big Gulp or standard Rotofab? Good time to move to the BG as well since that requires retuning due to the bigger MAF sample tube.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
05-20-2023, 01:55 PM | #5 |
Yeah I’m not doing meth, too many failed LT1s with that. I’ll only go as far as my current fuel system can go with E.
Have standard roto not big gulp, only concern is $$$ spent for tune if that’s the only mods. Might as well just wait, but I could justify it if I could drop a pulley size. lol. (At least in my head).
05-20-2023, 02:11 PM | #6 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
I wouldn't push boost any further on the SBE. If you do the Throttle Body boost will increase a little due to the supercharger being able to pull air in easier. Also if you do the Big Gulp it's going to want more fuel. So between those 2 mods alone you will be dropping down in the E55-60 range.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
05-20-2023, 03:37 PM | #7 |
Drives: 98 Camaro Join Date: Apr 2022
I’m guessing around 15-25hp with a bigger tb and cold air? Can you fit the Velossa tech scoop on there with the intercooler? That might be worth a few hp. Or definitely get rid of the snow/weather blocker if you haven’t already
05-20-2023, 09:43 PM | #8 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
I'm OK with the SBE up to about 730 RWHP, above that you'll be close the reaching the true mechanical capacity of the pistons - there is not much forgiveness at that level. Full E and the ability to deliver enough of it is your friend to maintain an adequate knock margin and have the engine survive (even if you make a mistake tuning along the way).
05-20-2023, 10:31 PM | #9 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Less boost and more timing if your on E and your not close to the HP that you need a Big Gulp. Your regular Rotofab is sufficient up to over 750 rwhp and that's according to Mike the owner of Rotofab, so when you get close to that get a big gulp.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
05-21-2023, 09:43 AM | #10 |
My car wanted 8-10% more fuel up top going from regular rotofab/95mm tb to Big gulp and 103mm. That was with the 3.5 8psi pulley. I could run E80 prior and had to drop back to E60 after those mods.
When I went to the 3.25 10psi pulley I had to drop down to E40. Installed a set of XDi +30 injectors(before affordable PI solutions were available) and that got me back to E60. A bigger fuel lobe to drive the HPFP harder should give it enough to run E80 again. Perhaps it depends on the supercharger inlet diameter and throttle body size more than a target power number because normally an engine doesn't lean out and require more fuel unless it's trying to make more power. I believe the Rotofab testing was done on a LT4 car that had a stock inlet and tb combination. So that will limit the potential of any gains up stream unless the supercharger is absolutely starving to pull air in.
2016 NFG 1SS A8
05-21-2023, 04:49 PM | #11 |
I may just hold off for now, the car makes plenty of power but that 87mm inlet just annoys me. Should have been 103 from the factory then folks could adapt down if they wanted too.
Might look at smoothboost and do that this year and get a pair of R888R for the rear. These SC3 just don’t cut it.
05-22-2023, 09:18 AM | #12 |
I couldn't imagine needing a smooth boost with a 2650 only making 10psi. Your issue is tires...a proper bolt-on car lays waste to SC3 tires.
2016 NFG 1SS A8
05-22-2023, 10:53 AM | #13 | |
Drives: '20 ZLE Join Date: Jun 2020
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
05-22-2023, 09:08 PM | #14 | |
I know I don’t need smoothboost now really but it’s something I want long term and figured while I have the money allocated from the wife might as well use it. Haha
