05-20-2023, 12:54 PM | #1 |
Drives: 2006 Pontiac GTO Join Date: Jul 2015
Issue with DIC display
Does anyone else have an issue like mine? Can this be fixed or a new cluster needs to be programmed and installed?
05-20-2023, 01:23 PM | #2 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
im not seeing what the issue is.is it stuck like that,or what? at one time i thought the light was out in my HUD but like a dumbass i had turned it all the way down while cleaning the dash...
05-20-2023, 04:14 PM | #3 |
It shows these tiny cracks and finish and if you look at the left side the blue is spilling over
05-23-2023, 07:41 AM | #4 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Never seen that type of issue before. I guess though the displays can go bad. I would think your only recourse would be to have the cluster replaced.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
05-23-2023, 11:40 AM | #5 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
If I remember right, those displays just pop out with one connection after you disassemble the actual cluster. Kind of a pain, but it's doable. You can find a used cluster and swap it out. I might even have a spare still sitting around. Save some money as far as not having to pay to have a new one programmed.
05-23-2023, 06:57 PM | #6 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
That looks like display rot, happens with old lcd displays over time, not really a viable way to fix it, best option is to get a new one or if doesn't bother you too much just keep using it until it gets bad enough that you can't see anything and swap it then.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
05-23-2023, 07:23 PM | #7 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
What year Camaro is this? I have almost about 94K on my 2010 and do not have this issue. Does your Camaro sit outside in the sun or is it garaged? I have not seen anything like this before. Also something to think about, do you detail your dash and cluster or do you just wipe it with a dry cloth? I'm wondering if some detailing components got behind it and caused that to happen?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
08-23-2023, 10:48 AM | #8 | |
08-23-2023, 10:49 AM | #9 | |
12-18-2023, 07:37 AM | #10 |
Drives: 2010 LS Victory Red Join Date: Mar 2011
I know this post is a few months old, but my display is in worse shape than that. I have a buddy at the salvage yard that has an instrument cluster off of a SS that has almost as many miles on it as my car and he says it's tip-top.
Can I just swap it out with the one off of a SS? My can is a V6 btw. I do have a Hypertech Programmer so I should be able to use that to re-calibrate the speedometer right? Also to add to the previous question, I do live in South Florida but my car lives in the garage all year round. Any help is appreciated.
Guro [Filipino/Tagalog (goo-roh) nee~guro} noun. An expert/master. Implies not only wizard skill but also a history of being a knowledge resource for others.
-Fifthgen Chevy Camaro Victory Red- -C4 Chevy Corvette White- |
12-18-2023, 07:54 AM | #11 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
It should fit, and you don't need to re-calibrate it for a display swap
12-18-2023, 04:55 PM | #12 |
No it's not. The connections are different. That's why I pulled it apart. I had both and thought the same. I'm sure you could really dive deep in there and cut and splice. But I just wanted to see if it was plug and play
12-18-2023, 04:57 PM | #13 | |
12-18-2023, 10:31 PM | #14 | |
Would I still be in the same boat or is it just because it's a cluster off of a SS?
