Old 05-22-2023, 10:40 PM   #1
ScarlettSS
Drives: 2013 Chevrolet Camaro 2SS/RS
LS3 rebuild, what to do while it’s out?
After a long battle of cosmetically fixing my 2013 SS and not being able to drive it much for the past year, cylinder #7 decided it didn’t want to play anymore…. Right after I got it painted and driveable.
A leak down test showed me #7 lost compession and being that it was leaking from the breather/oil fill area I’ve narrowed it down to piston rings. I’m going to be doing the rebuild myself this coming week or two and I was wondering what preventative maintenance/ reliability mods y’all would do to the motor. Currently it’s a cam only engine with long tube headers. I’d like to port and polish the heads while they’re out but leaving that as the only “power upgrade”. I just need the car to be reliable. Thanks for any help!
ScarlettSS is offline   Reply With Quote
Old 05-22-2023, 10:58 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
I know a ton of people forget about the oil diverter barbell. They make an inexpensive billet version. If you haven't already, replace the timing set and the tensioner with the dogbone type. Good quality set of lifters, maybe link bar type so you can lose the plastic lifter trays. Melling oil pump? Considered any ARP hardware for the bottom end?
I am intentionally leaving out all of the normal stuff that you are likely already replacing as part of the rebuild.
Old 05-23-2023, 12:08 AM   #3
JAFWF
Drives: 2010 2SS/RS 1994 Z/28 Convertible
[QUOTE=ScarlettSS;11319071]After a long battle of cosmetically fixing my 2013 SS and not being able to drive it much for the past year, cylinder #7 decided it didn’t want to play anymore…. Right after I got it painted and driveable.
A leak down test showed me #7 lost compession and being that it was leaking from the breather/oil fill area I’ve narrowed it down to piston rings. I’m going to be doing the rebuild myself this coming week or two and I was wondering what preventative maintenance/ reliability mods y’all would do to the motor. Currently it’s a cam only engine with long tube headers. I’d like to port and polish the heads while they’re out but leaving that as the only “power upgrade”. I just need the car to be reliable. Thanks for any help![/QUOTE
While you are doing the heads give serious consideration to shaft mount rocker arms
JAFWF is offline   Reply With Quote
Old 05-23-2023, 05:45 AM   #4
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
how many miles are on it & what is your budget. Pics of the bores would help also. If you have any severe cylinder scoring rings alone might not be the answer. Do you know how to use a cylinder bore gauge? If not you might want to consider sending the block out to have it checked out. If you don't start with a good foundation you will be inviting trouble. Rod & main journal measurements are a must. Post as many pics as you can.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 05-24-2023, 04:00 AM   #5
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
+1
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 06-02-2023, 09:18 PM   #6
oldman14ss
Drives: 2014 1ss camaro
inFID3vil, not jacking thread but, where do i get the billet oil diverter barbell from? i have a brand new LS3 im putting in a1975 coupe. and while its on an engine stand BINGO!
oldman14ss is offline   Reply With Quote
Old 06-02-2023, 09:22 PM   #7
morepowerjoe
I got mine from here https://www.michiganmotorsports.com/...66526de4cf499f
Old 06-02-2023, 09:46 PM   #8
oldman14ss
thanks joe.
