![]() Drives: 2014 1ss camaro Join Date: Jul 2017
fuel injectors
i'm putting a stock ls3 long block into a 1975 standard non matching numbers coupe. looking for some great, dependable,compatible fuel ijectors to fit the stock fuel rail and intake that i'm buying separate pieces for. no complete stock intakes available in the country and no hard gm resupply date so i'm pieceing it together. yes more expensive, not incredibly so but still. stealership just that. i used fuel injector clinic before. was going to call them. any of you vendors,fellow posters suggestions will be taken under advisement. i always appriciate your guildance and help. even if i cant spell for s**t anymore. trust me its age related. the oldman.........
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Pretty sure I still have the injectors that came with the Whipple I bought. Previous owner used them for about 500 miles and I went bigger on my install. Not stock, but not huge either if you are planning on more power.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
I'm still running the Siemens injectors from a Whipple on my turbo car and they have been flawless, but I am at the limit on them. More than enough for NA.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Wouldn't normally recommend injectors on EBAY but the ones from this supplier have been confirmed as good by users on HPT.
https://www.ebay.com/itm/274424906026 You will have to change some orings and space the fuel rails. |
i went ahead and ordered a/c delco thru rock auto. have brand new ls3 for my 75 camaro project. figured id keep all new with waranty. thanks for all the input though. the oldman..
