Old 05-30-2023, 10:56 PM   #1
JGaschTT
Drives: TT 2010 SS Camaro,Stock 2010 Camaro
Windows and Door Locks not working after taking doors off.
I have taken the dash out to get a 10 point roll cage installed. During that I removed all A/C components and airbags. I put everything back together everything works but windows, door locks, and the trunk open button. I have checked all of the wiring and grounds everything seems fine. The lights on the doors, and the side mirror adjuster works. Has anyone had a problem like this if so what did you do to fix it?
2010 2SS-Stock Block, TSP 416ci Stroker Kit, Rustan Performance Built 4L80e with Reid Super80 Case, Holley Dominator, AGP TT 6865 BB, BTR Stage 3 TT Cam, , AFR Mongoose 260cc Heads, Fore Triple 450s, ID1300x Injectors, Running Sunoco E85r. Best Pass 10.17 145
JGaschTT is offline   Reply With Quote
