Old 05-31-2023, 02:22 PM   #1
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Slight cut needed for my TT air filter fittment. Can or should I do it.
Hey guys ..... my driver side K&N turbo air cleaner fitment has always been a pain and install is not easy. I am thinking about cutting out this area in the silver lines on the pictures for easier in n out!
Do you guys think this is a good idea or will it cost structural integrity to be weakened. Thoughts?
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
Old 06-06-2023, 07:48 AM   #2
Pops
Drives: 2010 Camaro SS2 2012 C6 vette M6
Looks structural to me. However is possible to fab a brace to put behind and support after the cut. do not think I would cut without additional brace .
Pops is offline   Reply With Quote
Old 06-08-2023, 12:38 PM   #3
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
I agree since it is seam welded, it is probably structural to some degree. Will your car fall apart without it? Probably not... If it were my car I would go for it, especially if you are always taking the filters on and off. If you have access to a welder, maybe you could stitch up the seam with a weld after you cut it.
Follow me on instagram @Cthulu_the_trans_am
https://www.camaro5.com/forums/showthread.php?t=600181
2011 Camaro 2SSRS - Sold
No longer a 5th gen owner, but still an enthusiast. Ask me about my Front crash bars!
The_bald_eagle_machine is offline   Reply With Quote
Old 06-08-2023, 02:45 PM   #4
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Yep.....doing frequent filter swaps are imperative with the amount of air flowing thru these TT's. And you hit is on the nose my brutha, I will weld her up now that it is cut.
Old 06-09-2023, 03:00 PM   #5
bayarea408
bayarea408's Avatar
Drives: T
have you tried the aem dry flow air filter wrap? i run a big filter in the fender with no cover and it extends the life by alot.
bayarea408 is offline   Reply With Quote
Old 06-10-2023, 03:46 PM   #6
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
I never heard of that......do you have pics by any chance?
Old 06-12-2023, 01:13 PM   #7
bayarea408
bayarea408's Avatar
Drives: T
https://www.iwsti.com/cdn-cgi/image/...wrap.2310/full
I use one and inspect it all the time. I was at a car show and was talking to some Trophy Truck racers that use them running through wild sand situations in the desert.
Old 06-12-2023, 01:36 PM   #8
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
That looks like a great idea and solution my brutha. Thank you so much for suggesting that. I hope it is heat resistant for turbo applications.
Old 06-12-2023, 02:12 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
K&N has them as well..
https://www.knfilters.com/air-filters/filter-wraps.html
Old 06-12-2023, 05:28 PM   #10
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
That's excellent. Thanks for your input brutha.
Old 06-13-2023, 09:30 AM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You are welcome. Couple of my Camaro buds have them on their filters, and they look great. I'm going to order one for mine!
Old 06-13-2023, 01:11 PM   #12
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Think I am ordering them to. Thanks.
How do you like the LOD intake? Thinking about getting one... just worried about low end response.
Old 06-14-2023, 10:22 AM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hey there. I love my LOD! Looks really cool under the hood. Too many folks at the car shows think it is a SC! lol. Until I point out what it is to them. The only thing about it is it is designed to run upwards of 8000 rpm, and I don't have all the valve train needed to push it out there. When we tuned it we did run it to 7500 3 times to get the number we did, and it STILL wanted to make power at that point, but we stopped there for safety. As for low end response, I didn't lose any because I was running a 3200 stall, then went to a 4500 now and she just gets it off the line, no lack of low end on my build, with either the 3200 I did have or the 4500 now. The bad thing is I don't think LOD is still in business anymore, unless you can find them on FB. I had their phone number and have called and texted Rafeal several times because I have some friends here that want one too, but haven't heard anything back from them. It does make great mid range numbers all the way out the door. Here is a vid where GPI tested it along with others.
