![]() Drives: 2015 Chevrolet Camaro 1ss 6sm Join Date: Oct 2022
I have been slowly ordering all my parts for my cam swap for my 2015 Camaro ss m6 (ls3) and im almost ready to get started on it. But I've read different stories on the stock ls3 lifters being able to handle a cam, i wasn't really planning on doing lifters but i need some advice on this. the cam specs are 233/253 .646/.637 and I would like to know if one of you are running this cam or similar cams with the stock ls3 lifters before i buy the ss3
Also, im open to other cam options but really like the GPI ss3 Thanks in advance!!
#2 | |
I'm only running an SS1 VVT, but I bought Johnson 2110R lifters to go with it. You are going to get similar opinions from folks smarter than me as this thread continues.
Power: 475 WHP; 443 WTQ
Mods: GPI SS1 VVT cam; GPI ported heads; GPI ported TB; GPI Rod Mod intake manifold; Vararam CAI; TSP 2" LT headers; TSP 3" exhaust; Mighty Mouse Wild catch can; 3.91 GM gears; Truetrac; LPW diff. cover; Whiteline diff. bushings; NT555RII drag radials (315/35R20) |
GPI Sales Consultant
As someone who helps customers build out cam packages every day for a living, I can tell you that the most common failure point I see in LS engines is the lifter. Consider adding a camshaft exposes the factory lifter to additional valve spring pressure, additional lift, a faster opening/closing ramp on the lobe, and more rpm. That's asking a lot from that part, especially if it already has seen plenty of miles. For the money, the Chevy Performance Racing (aka GMPP, Caddy, P/N 88958689) lifters are a huge step up from the factory LS3/LS7 lifters in terms of material and build quality - they are not only better performing but more reliable. We use those in probably 80% of the builds we do here in the shop because they are an excellent lifter for the money.
Whatever you do, don't go backwards on lifter quality with a knock-off "Delphi LS7" wanna be lifter, or some other low cost substitute. You get what you pay for, and find something just as good as OEM for half the money is a fantasy. The only thing those are good for is paperweights. As far as the cam, I ran that cam in my personal 2011 LS3 Camaro for over 20,000 miles. I loved it - it made great power (501whp with bolt ons, ported rod mod), and was reasonable to drive around. It is a BIG cam, make no mistake. It's true that it's our "Stage 3" option, but compared to our competitors "stage 3" options, it's a big stick. The history is that the SS3 was our original "max effort for internally stock" LS3 applications. Eventually, we massaged that cam into our SS4 NFC, which offers just a little more top end power at the expensive of a little early mid-range. The SS3 actually has MORE overlap than the SS4 NFC, and will drive just the same - it will have big cam qualities (small bucks and surges) under light load at low rpm (<2000). Good tuning will mitigate a lot of that, but you cannot mask it completely, especially in a stick shift car. If you're looking for more a pure stage 3 option, I have a custom grind that I do for customers that is a bit more centered between our SS2 and SS4 NFC cams. I call it the "Cammer", and it's a 231/247 112+4, on the GPI/GPX lobes the rest of our lineup is on, so the same .646/.637 lift. It's aim is to be a bit better driving than the SS3 and SS4 NFC by taming the overlap a bit. It will have a similar curve with a VERY strong mid-range, and a peak around 6400rpm with a solid curve out to 7000rpm, giving up maybe 10-15hp to the SS4 NFC and 5-10whp to the SS3. Pretty similar big cam sound and performance, but a little less of the big cam manners. Anyways, I hope that helps. If you decide you want to go the GPI route, I'd be very happy to help get a complete cam package sorted out for you when you're ready. You can reach me via e-mail at andrew@gwatneyperformance.com, or you can look me up on facebook and feel free to message me to get a package together, or just with additional questions.
Got a question about a GPI product? Feel free to shoot me a message! |
#4 | |
![]() ![]() ![]() Drives: 2011 2SS/RS Join Date: Feb 2016
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
![]() Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
Yep, start with the Caddy lifters and go up from there. I just got them in my mild vvt build and if you are spinning even higher than 7k I would probably invest in johnson lifters but caddy lifters(GMPP lifters) is where I would start.
#6 |
Agree with all the above. Start with the caddy lifters, then if you are going to go wild with a max effort build and spin some RPM's, then Johnson is the way to go. I'm kinda pissed that my builder went with the Delphi's in my build. Not sure why, but when I found out how NOT reliable these lifters are above 7k RPM, and I ran it up there a lot, I had to quit driving my Camaro like it should be driven, hence took away most of my enjoyment. Just afraid they may fail, so I'm easy on it, and right now that I don't have anymore "extra income" being retired, can't afford to replace them. So DON'T cheap out!!
#7 |
![]() Drives: '13 Camaro SS '98 Firebird Formula Join Date: Mar 2022
I'm probably tempting fate, but I slapped my BTR Stage 4 LS3 cam in using the stock lifters and I've been ripping on it for about 5000 miles with zero issues. Starting at 82K miles. Is it the right thing to do? No. Did it work for me? Yup. That said, when I finally decide to buy heads, I'm going to swap out my lifters for quality pieces.
#8 | |
Do as I say, not as I do, right? Or in this case, now it has the Max Package 2.0 on it, and Johnson ST2116LSR's that I rip to 7800rpm and don't give a second thought to. I definitely recommend that!
#9 | |
#10 |
Plus the caddy lifters are only like 120-150 more and GM rated them to 8k. Johnsons are better but unless you are really spinning that ls to 7500 plus like Andrew regularly. You don't need more lifter than the caddy imo.I wouldn't even consider Johnsons personally. Invest in ported heads, higher end valvesprings etc.
#11 | |
#12 | |
Thanks.
#13 |
Alright thanks for the responses! ,I’m going to be upgrading my lifters now , I will be going with the GPI ss3 cam debating on get the ss3 sc cam bc I do plan on getting a 2.9l whipple sc kit for it very soon. Anyone got any thoughts on that ? I really do appreciate all the help guys !
#14 | |
Oh, and it's Whipple, not whipper. lol.
| Tags |
| cam conversion, gpi ftw, lifters, ss3 |
