Old 06-01-2023, 03:06 PM   #1
sambocaesar
Drives: '13 Camaro Convertible 1LT
Quarter Window Seal Disappeared
2013 Vert owner .. rear passenger quarter weatherstrip was lost in my last ride with the top down. Searched interior with no luck. I'm reluctant to buy whole quarter window ($300) just to get weatherstrip replaced. Many part sites show the 2013 version is not available. I did find the 2016 quarter window for $70. Can't tell if the weatherstrip is the same as what is on the 2013 quarter window. If it is, this would be easier on my wallet than the 2013 version, assuming one could remove 2016 seal and place it on the 2013 window. Does anyone have any idea if the weatherstrip on 2016 model is same as 2013 model? TIA
sambocaesar is offline   Reply With Quote
Old 06-01-2023, 03:36 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Originally Posted by sambocaesar View Post
2013 Vert owner .. rear passenger quarter window seal was lost in my last ride with the top down. Searched interior with no luck. I'm reluctant to buy whole quarter window ($300) just to get window seal replaced. Many part sites show the 2013 version is not available. I did find the 2016 quarter window for $70. Can't tell if the window seal is the same as what is on the 2013 quarter window. If it is, this would be easier on my wallet than the 2013 version, assuming one could remove 2016 seal and place it on the 2013 window. Does anyone have any idea about this? If not, I guess I could buy it to try it and see (no returns since 2016 window doesn't fit 2013). TIA
Do you have a local "bone yard" around? If so, I would look there and see if there are any wrecked Camaros and pull it from there. Save a lot of money!
Old 06-01-2023, 03:43 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You could also check with these folks.
https://www.hawksmotorsports.com/sal...o/2010-camaro/
Old 06-01-2023, 04:57 PM   #4
sambocaesar
Checked local salvage .. no luck
Thanks
Old 06-01-2023, 04:58 PM   #5
sambocaesar
Checked here .. nada
Thanks
Old 06-01-2023, 05:23 PM   #6
gtstorey
https://www.gmpartsonline.net/oem-pa...Y2LWdhcw%3D%3D
Both also look like they are available on EBAY also.
Old 06-01-2023, 05:44 PM   #7
sambocaesar
Originally Posted by gtstorey View Post
Not applicable here .. I'm needing weatherstrip that was attached to the quarterwindow
Thanks anyway
Old 06-02-2023, 10:33 AM   #8
sambocaesar
Cool Inexpensive Fix/Alternative
I may have found a solution that doesn't require a new window purchase. I will post back after I apply this fix.
https://youtu.be/noeLo89HXDI
Old 06-02-2023, 10:45 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome man! Good luck..
Old 06-02-2023, 07:16 PM   #10
Whoomba
Drives: 2024 Camaro 2SS CE Convertible
Work out ? 2013 and 2016 aren’t the same.
Whoomba is offline   Reply With Quote
Old 06-03-2023, 11:26 AM   #11
sambocaesar
Was considering getting the 2016 window just for the attached weatherstrip due to the price difference, $300 (2013) vs $70 (2016). However, I’m going to try a $10 solution, for all intents and purposes, should work.
Old 06-06-2023, 01:11 PM   #12
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
many a vert have lost that rear window seal...curious to see what you come up with!
MSgt O is offline   Reply With Quote
Old 06-06-2023, 08:13 PM   #13
sambocaesar
Window Seal, aka weatherstrip installed
Bought a 2-inch door sweep (instead of 3-inch one) from Amazon, as it was closer to the width of the original weatherstrip. I cut it to exactly 12 inches with the top at a slight angle to match the top of the rear quarter window. After removing the protective strip from the adhesive, I was able to work the bottom of the sweep between the rubber and the bottom of the glass and align the rest along the window edge. The top of the cut door sweep lined up with the top of the window. The only issue I ran into, that I haven't resolved yet, is that with the top up, when I tried to raise the rear window to the closed position, it would get half way and then auto-reverse back down into the body. After several tries, it finally would rise and seat into the channel of the top, so I left it alone, with the top up. I'm not sure what is causing the reversal, but I will try to troubleshoot it later. It is not a perfect solution, since the door sweep does not have a 'steel' back to support it, like the original. However, it does seal enough to keep light moisture out. I'm not sure if it will prevent a heavy rain from entering. The wider 3-inch may work better, but the 2-inch looks like the original strip from afar .. it's a closer match. I'll try to add pictures, as soon as I figure out how to do it here.
Links for the door sweeps:
https://www.amazon.com/dp/B07JPH63DZ...roduct_details
https://www.amazon.com/dp/B081Q3THZN...roduct_details
Old 06-06-2023, 08:43 PM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
On the top of your "repair" piece, check the thickness of it where it goes into the top, it might be just a tad too thick and it is getting caught in the tops channel. Taper it a bit on the very top side and see if that fixes it. The auto reverse back down is indication the window is geting pinched somewhere. It's one of our safety features on our windows. GL.
