Old 06-02-2023, 08:59 AM   #1
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Disaster Struck
So my car had what I suspect was a failed fuel line on Weds which led to a massive car fire. Everything under the hood wires / plastic / hoses got cooked. Even had some fire get into the cabin on the passenger side just forward of the shifter on the tunnel next to the gauges. So I am getting ready for an adjuster come and get the car but I know they will want mileage for a virtual adjustment prior to having the car towed. I have a squash dual pump system in the car and if i turn the key on it will just spray fuel from the broken line. Would just pulling the fuel system control fuse in the trunk stop that pump from coming on?
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 06-02-2023, 10:08 AM   #2
Bildo
Bildo's Avatar
Pic of the poor car
Old 06-02-2023, 10:08 AM   #3
jeff657756
Drives: 2014 SS 1LE
Just disconnect the main pump(s) wiring from the battery. Relay will still come on but no power to the pumps.
jeff657756 is offline   Reply With Quote
Old 06-02-2023, 10:28 AM   #4
Bildo
Bildo's Avatar
Totally forgot I wired them directly to the battery, its been about 5 years since I did the fuel system.
Old 06-03-2023, 09:02 AM   #5
cc-rider
Drives: 2010 Camaro SS
That sucks. Sorry that happened. Where did your fuel line break at?
cc-rider is offline   Reply With Quote
Old 06-03-2023, 09:31 AM   #6
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
chevy pilot is online now   Reply With Quote
Old 06-03-2023, 11:26 AM   #7
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Wow....sorry brutha.
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
