Old 06-08-2023, 02:16 PM   #1
sbelyo
Drives: n/a
2013 ZL1 with LT headers and a pulley, it needs a fuel pump
A few weeks back I picked up a 2013 ZL1 Auto with 60K miles on it. It has a 2.5" pulley, long tubes, we think no cats, 3 inch exhaust with X pipe all the way back to stock mufflers. I took it to a tuner here in Ocala FL with a good rep so he could take a look at it to make sure it was safe to drive it and get on it it etc etc without breaking it.. He put his laptop on it and took it for a drive. He said that its got good power but noticed that torque management was missing on the downshifts and that would kill the trans if left that way. He also said that the injector duty cycle hit 126% and this leaned out the motor with some detonation on the top end. He recommended replacing the stock fuel pump to fix the duty cycle issue. He mentioned that the stock fuel pump and injectors should be just fine with the mods that are on the car and that he's seen this before and fixed it by replacing the fuel pump. I agreed so I had him order the pump and will let them do the install along with replacing the rear mag ride shocks and a proper tune.
Is there anything else I should do?
sbelyo is offline   Reply With Quote
Old 06-08-2023, 05:30 PM   #2
bsn
Drives: 2013 ZL1
That's about 18% overdrive, I would think you would need a stock fuel pump + boost a pump or aux pump + bigger injectors to be safe.
bsn is offline   Reply With Quote
Old 06-08-2023, 08:07 PM   #3
FASTFATBOY
Drives: 2013 ZL1
Mine makes 600 wheel with a stick shift and the stock pump has no issues.
2.4 pulley
Ported throttle body
No cats
Intake
ID 1000 injectors.
Sounds to me like you need injectors, not a pump. Stock injectors are done at about 540 wheel. If your tuner does not know that you need a new tuner.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 06-08-2023, 09:50 PM   #4
sbelyo
Drives: n/a
I found an online tool that shows it adds about 10%. I should add that the lower pulley is stock
Old 06-08-2023, 09:52 PM   #5
sbelyo
Drives: n/a
I thought about this after I left as well. I'll do some more research
Old 06-09-2023, 06:47 AM   #6
FASTFATBOY
Drives: 2013 ZL1
Get a new tuner, that guy will blow your shit up.
Call Janetty, he'll get you fixed up.
Old 06-09-2023, 01:31 PM   #7
sbelyo
Drives: n/a
Noted... I'm in contact with jeremy from fasterproms. Lets see where this goes
Old 06-09-2023, 03:51 PM   #8
sbelyo
Drives: n/a
In order to keep this sane I feel like I should go up to a 2.75" pulley. I have an ADM hub.
https://lsa-conversion-store.myshopi...version-pulley
I believe the stock belt size should fit but there's no chart that shows a 2.75 upper and stock lower. I did find a gates HD belt that is 3/16" shorter than stock so I think this should fit
https://www.gates.com/us/en/power-tr...555-00224.html
This combo will lower the boost to help keep the motor safe correct?
Lastly I found my HPtuners MPVI2 with 2 credits unused. Can I use this to log data to see what the injector duty cycle and fuel pressure are?
Old 06-09-2023, 05:44 PM   #9
roh
Drives: 2013 ZL1
I bought a car with a very similar combination as you, except the 3".
I log with HP tuners & just checked a 1/4 mile pass. My highest injector duty cycle was 51٪. Fuel pressure was about 65lbs.
I don't know whats in the tank, but no boost a pump or aux pump. Injectors appear stock.
roh is offline   Reply With Quote
Old 06-09-2023, 07:12 PM   #10
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
All you need is a aeroforce gauge it will scan all the parameters for you.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 06-09-2023, 08:16 PM   #11
bsn
Drives: 2013 ZL1
Yes you will need to use both credits but HP tuners will log your injector duty. you really need don't want to get above 80% duty.
Old 06-09-2023, 08:41 PM   #12
sbelyo
Drives: n/a
That's interesting, it almost lends some truth to what the tuner was saying. Do you have a 2.5" pulley or larger?
Old 06-09-2023, 08:44 PM   #13
sbelyo
Drives: n/a
That's really cool
https://aeroforcetech.com/collection...et-camaro-2010
Old 06-09-2023, 11:18 PM   #14
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
I really like my aeroforce gauge ..
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.5@135
Risingson05 is offline   Reply With Quote
